If there's a discount on the NA back box I would be interested. But it would need to be cheaper than the price on the website currently (same as tubby above).NA back box is the same price as the tubby..
Cheers Nathan
Phil
Posted 01 February 2007 - 07:25 PM
Cheers Nathan
Posted 01 February 2007 - 07:48 PM
Posted 01 February 2007 - 09:24 PM
Posted 02 February 2007 - 10:11 AM
if i put my name down for a back box, when will you need payment....... i'v just booked a big holiday so got nothing spare at the mo....come to think of it it's going to be 6 weeks till i could pay up...... how do you want payment is it to a forum member or is it to larini direct, that way i could flex the plastic....again...
Posted 02 February 2007 - 11:16 AM
Back box £550 less 20% = £440
Posted 02 February 2007 - 11:19 AM
Posted 02 February 2007 - 03:59 PM
Posted 02 February 2007 - 06:16 PM
Posted 02 February 2007 - 08:37 PM
Posted 02 February 2007 - 09:01 PM
The list is still relatively new and is only open to uk owners (as there are european larini distributers), the list stands at...
Posted 02 February 2007 - 09:19 PM
Posted 02 February 2007 - 11:49 PM
Posted 03 February 2007 - 08:06 PM
so will the the backbox make a sound difference??how much is it for the full system?
im getting tempted
Posted 05 February 2007 - 06:34 PM
Dear Sir,
Thank you for your enquiry. We welcome the chance to supply you with one of our high performance, stainless steel exhaust systems.
We can offer you the following:
1. 2000-03> Vauxhall VX220 2.2 16v, Larini ‘Sports’ System … £452.80 plus Vat = £532.04
2. 2000-03> Vauxhall VX220 2.2 16v, Larini ‘Sports’ Cat … £TBC plus Vat = £TBC
3. 2000-03> Vauxhall VX220 2.2 16v, Larini ‘De-Cat’ Pipe … £TBC plus Vat = £TBC
* Delivery = + £13.50 plus VAT = + £15.86
* Delivery schedule = IN STOCK
__________________________
1. Vauxhall VX220 2.2 16v, Larini 'Sports' System:
- Stainless Steel 'fast road' use sports exhaust, from the ‘cat’ back.
- Delivers an extra 5 bhp approximately.
- Offers vastly improved low/mid-range Torque.
- Produces a fantastic 'Note' under acceleration, without suffering from drone or vibration.
- Delivers much sharper throttle response.
- Engineered for maximum flow efficiency, using heavily redesigned 'straight - through' pipework.
- Incorporates larger diameter pipework.
- Accelerated gas-flow reduces engine bay operating temperatures.
- Weight reduction of over 50% compared to OE, significantly benefiting handling and braking ability.
- Perfectly practical for everyday use: does not suffer from excessive resonance at idle or cruising speeds.
- Decibel reading = 95 db from 1 metre at a 45 degree angle.
- Features two stunning 3-inch polished and rolled Round tailpipes, lined with metallic conical cores.
- Constructed using aircraft grade T.304 Austenitic Stainless Steel.
- Features Mandrel bent pipe-work allowing a constant internal diameter, maintaining a smooth, constant gas flow.
- 100% Tig welding construction.
- Features highly polished box casings, pipework and tailpipes, offering a 'chromium' type finish.
- Precision engineered for accurate fit. Requires no special procedures or undertray modifications to fit.
Superior Sound - The common complaint with the Vauxhall VX220 2.2 16v is its 'flat' sound. We have eradicated this. Our System sounds phenomenal throughout the rev range and screams in the higher rev range. Using octave band frequency monitoring techniques we have been able to develop a System which produces the Larini 'Note' under acceleration as opposed to the resonance, drone and excessive volume present in other aftermarket systems.
Our System does have more volume than the original but it is not offensive. The volume increases with revs so as not to intrude into the cabin, but sounds fantastic when 'pushing', gaining volume with throttle input, and is perfectly practical for everyday use. You’re VX220 2.2 16v will now sound as spectacular as it looks.
More Power - Our free flow design gives an extra 5 bhp approximately. Once the 'Sports' system is fitted to your car you will find that the engine is more free-revving and that there is an increase in low-down torque, with an improved throttle response.
Developments such as redesigned internal 'straight-through' silencer pipe work and larger bore pipe work (where necessary), help emit exhaust gasses quicker - with a reduced build up of back pressure, allowing the engine to 'breathe' and perform better. Our system adjusts backpressure levels to their optimum to produce the correct levels of supercar performance and sound.
Additionally, this system has been developed to run on cars developing up to 200+ bhp, without restricting power.
Weight - 7 kilograms.
Visible Quality - Features two 3 inch inwardly rolled, Dual-Walled, Round Tailpipes, lined with metallic conical cores. Tailpipes, box casings, inlets and brackets are all 'chromium' polished. Our Tailpipes perfectly fit the profile of the rear of the VX220 bumper. Our System features Tig welding and double skinned box casings for maximum durability and sound control.
From when you first take delivery and open the box you will see the difference.
Ease of Fit - Our System fits perfectly to the 'cat' and mountings, requiring no special procedures or modifications to the car or trimming of the bumper exit points.
Guarantee - Larini Systems Lifetime Warranty.
___________________________
2. Vauxhall VX220 2.2 16v, Larini ‘Sports’ Cat:
Delivers an extra 7 bhp approximately.
Delivers an extra 12 lb-ft of torque approximately.
200 cells per square inch for maximum flow with minimal backpressure.
No adverse legal, environmental or technical implications.
Guarantees a more free-revving engine with improved throttle response.
Significant horsepower gains and a huge increase in torque.
Engineered for maximum flow efficiency, using complex internal METALLIC Cat ‘cores’ (Larini Metalith).
Increased diameter pipework throughout.
Parabolic megaphone inlet cone design guarantees even flow distribution across the Metalith core - whilst minimizing packaging length.
Reversion pulse outlet cone activates catalytic material for full length of the Metalith.
Ultra durable T.316 Austenitic stainless steel heat casing protects components from heat distortion.
‘Cat’ is rated up to 300 bhp.
Vastly freer flowing in comparison to the standard ceramic cat.
Engineered for maximum flow efficiency using larger diameter pipe work throughout.
Direct bolt-on replacement for the OE primary/secondary catalyst section.
Massively accelerated gas-flow reduces engine bay and operating temperatures.
Cat is fully 'Mirror Finish' Polished.
'Satina' polished and 'Lime Chalk' waxed pipe work.
Correctly positioned, heat-distortion resistant, CNC-machined stainless steel Lambda bosses.
Furthermore, torque increase is higher than that of a de-cat pipe as backpressure levels are modulated optimally. Once fitted, no modifications will be required to the engine management system.
NB: Vehicles manufactured post 1994 require a catalytic converter for U.K. MOT emissions legislation. Vehicles subject to U.K. police roadside emissions checks may struggle if running a de-cat pipe. They will not if equipped with a Larini 'Sports' Cat - in fact they will register cleaner emissions over the OE catalysts.
Technical:
The VX220 2.2 16v OE, single piece, cat section incorporates a primary catalyst followed by a secondary catalyst. This is to regulate low emissions levels for the Speedster. These stock ceramic cats offer a combined 600 cells per square inch, offering an approximate 55% flow area. These factory cats are hugely restrictive. Ultimately, this combined arrangement saps power. Enhancing power from within this area involves carefully tuning a singular catalyst to work with the manifold.
A Larini METALLIC ‘Sports’ Cat for the VX220 2.2 16v incorporates only 200-cells, is rated up to 300 bhp, and offers a flow area of approximately 96%. This arrangement is the performance ideal - significantly adjusting backpressure levels and enabling increased flow rates. Exhaust flow is almost completely unobstructed through this 'sports' component and as result there is an extremely noticeable power gain and a significant increase in torque. The complete cat section is manufactured using larger diameter pipework to aid gas outflow. Once fitted, one can expect much sharper throttle response from a now free-revving engine, with cooler operating temperatures. Temperatures are reduced, as accelerated gas-flow minimizes engine-bay temperatures by dissipating heat more effectively. This is particularly important for improved performance, as cooler temperatures boost engine efficiency while protecting the manifold from damage.
Furthermore, a stronger braided stainless steel flexible bellow is incorporated in the cat section, to cope with the increase in engine performance output.
A Larini Cat is Euro-3 emissions level rated - returning cleaner emission results than the standard catalysts, making it possible for vehicle tuners to obtain high power gains, whilst meeting government emission levels and staying road-legal with high reliability. Unlike illegal de-cat pipes, there are no negative technical consequences associated with fitting this innovative product - the original lambda probes are retained in their correct positions for the proper operation of the OBD II (On Board Diagnostics II) system. Furthermore, fitting the Larini ‘Sports’ Cat guarantees an increase in the crispness of the engine’s 'note' and 'tone'.
The improved quality of a Larini ‘Sports’ Cat is immediately noticeable as soon as it is removed from its box.
3. Vauxhall VX220 2.2 16v, Larini ‘De-Cat’ Pipe:
Delivers an extra 9 bhp approximately.
Delivers an extra 10 lb-ft of torque approximately.
Vastly freer flowing in comparison to the standard catalytic converter.
Engineered for maximum flow efficiency, using larger diameter, ‘straight-through’ pipe work.
Direct bolt-on replacement for the OE catalyst.
Pipework and bosses are fully 'Satina' Polished and 'Lime Chalk' waxed.
Mandrel bent pipe work allows a constant internal diameter, maintaining a smooth, constant gas flow.
Constructed using aircraft grade T.316 Austenitic Stainless Steel.
Correctly positioned, heat-distortion resistant, CNC-machined stainless steel Lambda bosses and heat probe connections.
Requires no special procedures to fit.
Supported by the Larini Systems Lifetime Warranty.
The Larini ‘De-Cat’ Pipe is a high temperature resistant, hollow pipe, which replaces the highly restrictive OE primary/secondary catalytic converter section. Exhaust flow is completely unobstructed through this larger diameter 'straight-through' component and as result there is an extremely noticeable power gain. Temperatures are reduced too, as accelerated gas-flow minimizes engine-bay temperatures by dissipating heat more effectively. This is particularly important for improved performance, as cooler temperatures boost engine efficiency. Engine performance is notably aided, once coupled with the Larini ‘de-cat’ pipe. A stronger braided stainless steel flexible bellow is also incorporated, to cope with the increase in engine performance output.
Furthermore, the muffling effect provided by the bulky OE catalysts is eliminated, significantly enhancing volume levels.
Re-assurance:
We supply our Systems to car collectors all over the world, such as the Danielli Collection (Italy), the Jordanian Royal Family, and the Alain Bourgeois Heritage (France). Poor fit and finish is not an option with our products. I attach some examples of our work.
All of our exhaust Systems come with our Lifetime Warranty and are designed to fit accurately, look correct and sound authentic. We value our reputation and your driving pleasure. We only develop our Systems to the vehicle, as opposed to just replicating the components off the vehicle.
Recent Larini ‘Standard’ System specialist commissions include a Ferrari 275 GTB Longnose (only 205 built) and a Ferrari 400 Super America (only 47 built).
Recent Larini ‘Sports’ System specialist commissions include a Ferrari 500 Superfast (only 36 built) and the Warner Bros. 2004/5 Batmobile (only 13).
Ordering:
To order your Larini System please contact us via telephone, online order form, fax or e-mail, with a credit card.
All orders placed will be invoiced and charged in GBP (£). Quoted foreign currency prices are subject to change due to exchange rate fluctuations.
If you require any further information please do not hesitate to contact us directly.
Kind Regards,
Neil Macauley
(Technical Director)
Larini Systems Ltd.
Units C, D2 & D3 Devon Business Park
Saunders Way, Kingsmill Ind. Estate
Cullompton
Devon
EX15 1BS
United Kingdom
Tel: +44 (0) 870 777 9060
Fax: +44 (0) 870 777 9070
E-mail: info@larinisystems.com
Web: www.larinisystems.com
This article is copyrighted ã 2007 Larini Systems. All Rights Reserved.
All content included herein, is solely the property of Larini Systems, and is protected by United Kingdom and international copyright laws.
You may therefore not extract, use, copy, reproduce, duplicate, sell, or resell, any parts, components, or content of this article for utilization in any commercial purpose, without Larini Systems’ express written prior consent.
Edited by Blue VXR # 65, 05 February 2007 - 06:36 PM.
Posted 05 February 2007 - 07:15 PM
Posted 05 February 2007 - 07:33 PM
Posted 05 February 2007 - 07:45 PM
Posted 06 February 2007 - 08:36 AM
Posted 06 February 2007 - 09:24 AM
Posted 06 February 2007 - 09:34 AM
I'm not really understanding the price structure.
from the website:
Sports BB for Na is £452
a 20% discount would make it £360ish.
If anyone can confirm the above, then i'll take part but uping the price to provide a discount is
