Front Numberplate Fell Off...
Posted 29 January 2007 - 08:21 PM
Posted 29 January 2007 - 08:28 PM
Posted 29 January 2007 - 08:42 PM
i have not replaced it. i drive without.
since then i have done over 4000 miles with no problems, no fines ..... touch wood.
i don't drive recklessly but it kinda comes in handy down the M4 doing 80 to 85 MPH with eyes on the bridge taking little pics...
what would happen if they stop you, a friend of mine got stopped in the summer and only got a £30 fine and a producer.... if this is the norm , who needs a laser diffuser....
(not that i would do this as it's illegal)
Posted 29 January 2007 - 09:26 PM
Posted 29 January 2007 - 09:38 PM
I'd ditch the double sided foam tape, it's rubbish.
Pop to your local B&Q or similar and get some heavy duty velcro but you'll still need to clean all the other stuff off first.![]()
I would have thought the numberplate would be fine in the window until you sort it out properly, you can say it just fell off if you get stopped!
Posted 29 January 2007 - 09:52 PM
Posted 29 January 2007 - 09:58 PM
Posted 29 January 2007 - 10:11 PM
I wouldn't say the plate just lifts off that velcro - its pretty industrial strength, you could probably snap or permanently bend the plate if you're not careful.Alternatively if I'm feeling law-abiding, presumably the velcro requires both surfaces to be clean and all old sticky crap removed... and then the numberplate is removable whenever I fancy, like normal velcro?
I can see both benefits and problems with this... firstly if I leave the numberplate affixed (with velcro) then it can be easily stolen if left on the car. Secondly I can remove it when doing long journeys with average-speed cameras.....
Go for a 3/4 sized plate - they look far better and they must be slightly more efficient. You can still get nicked though with the 3/4, not that I have, yet. Keep the original plates with you and plead ignorance or say you've just left/on way to a track day - may not work, but worth a go.
Edited by Spindoctor, 29 January 2007 - 10:13 PM.
If stopped, is it an immediate fine or at the officer's discretion? And if I have a plate in the car that I can slap on as soon as the cops stop me, will that stop them from issuing a fine? Maybe the velcro would make the cop smell a rat (if it's that easy to use then it should be on the car in the first place, presumably....)
Having no front plate (but one in the boot just incase) spells out to the copper that "I know I am doing wrong but I thought I would get away with it"
"Where is your front plate sir?"
"Ive got one in the boot"
"Well why is it not on the car sir?"
"Errrm??"
It may just get mr policman more annoyed and issue you a fine anyways.
You could use the excuse that you have removed it for a trackday and just forgot to put it back on tho..!
Ive got a 3/4 front plate, it looks great and i have yet to be stopped.. I will one day though I bet..
MED..
Edited by medlow, 29 January 2007 - 10:15 PM.
Posted 29 January 2007 - 10:28 PM
Posted 29 January 2007 - 11:01 PM
Posted 29 January 2007 - 11:16 PM
Edited by sworks, 29 January 2007 - 11:18 PM.
Posted 30 January 2007 - 12:00 AM
I think you got it .Maybe keep a 'broken' plate in the boot and tell them the number plate caught a speed bump and got ripped off. Thought this was the reason velcro is used instead of screws, to avoid the screws ripping through the nuber plate plinth.
Not that i would do this!
That the solution keep a broken one in the boot.
What a bout one of those adhesive plates they use on caravans ?
Posted 30 January 2007 - 11:12 AM
Posted 30 January 2007 - 11:52 AM
Posted 31 January 2007 - 07:47 PM
Is this illegal? The numberplate is visible to the carpark nazis, and will be visible to cars coming the other way if I drive it, but will most certainly not be visible to speed cameras
Should I not drive it until I get the numberplate fixed on again, and if the carpark nazis give me a ticket for 'not displaying a numberplate' then surely I've got a leg to stand on to fight the fine?
As you probably know its all covered by the Vehicle Excise and Registration Act 1994 s42 and s43.
s42 covers offences relating to fixing of the plate and s43 to the plate being obscured or 'not easily distinguishable'.
Offences under either of the above are liable to a fine, and the onus of proof is on the defendant (i.e. the driver) that they haven't committed an offence. I would imagine sticking your plate inside the car on the dashboard/inside the boot as falling under s43 (less easy to argue away obviously if its in the boot!!!)
Therefore, if the relevant "car park nazi" works for the local authority then you may be able to blind them with rhetoric. If however, the alleged offence was in a place overseen by the local constabulary then you can probably place the words creek, paddle and sh*t into a suitably arranged sentence...!
JJ
Posted 31 January 2007 - 08:11 PM
Posted 31 January 2007 - 10:15 PM
Posted 31 January 2007 - 11:18 PM
If you do get stopped and you havent got one, just tell the copper, "well officer i checked it was there this morning whilst i was checking all my lights were working, so it must have fallen off"
What can they say!!!!
Ding
They frown more about small plates rather than not having one at all
