Measured the exact weight of the original ones?
Looking forward to your experiences on the road/track
I had measured the OEM caliper's weight and the result was about 3 kg (without pad)
My first impressions regarding this caliper in comparison with technical description of Hi-spec web site, hereafter :
Features
Patent pending
CNC Machined Lightweight Aluminium Body
Fully Dust Sealed
Rigid Design
Internal Fluid Crossover
Integral Self Adjusting Handbrake Mechanism
Direct replacement for Vaxuall VX220 / Elise S2
Technical Specification
Disc Width 10mm, 12mm, 20mm, 24mm
Piston Size 2 x 38.6mm
Piston Material Hard Anodised Aluminium
Pad Size 76 x 65 x 14mm
Weight 950g
Hydraulic Thread M10 x 1.0
* These calipers are described as "Fully Dust Sealed" : I did not see any ruber below on the piston.
So for me this description is untrue and I am afraid that in the next futur, calipers pistons could be blocked by brake dust or other dirt.
* Handbrake mechanism seems to have "very poor design engineering" and Hi-spec disclamer reinforce myself in my convinction ...
(Hi-spec advice to put a gear while you operate hand brake mechanism
* Indicated weight is wrong of about 30%
* Caliper alone is not a direct replacement of OEM caliper some adjustements are necessary to install it
To sump up : Hi-spec description is a bullshit.
I am not sure I will intall these calipers on my car especially regarding '"dust sealing" problem
(I think that life expectancy of such caliper without real dust seal, should be very short for a road use).
Sincerly, I regret this purchase ...
Edited by chris, 30 October 2007 - 05:11 AM.
