Supercharger
Posted 23 April 2007 - 03:00 AM
Posted 23 April 2007 - 03:20 AM
petrolhead1, on Apr 23 2007, 04:04 , said:
speedster, on Apr 23 2007, 04:00 , said:
Today, I just bought a stage 2 supercharger kit!
How much? What's included? Who will do the remap? Can't leave us hanging we need much more information.
Here's what I got
- Supercharger + intake manifold + gasket set
- Stage two drive pulley
- Set of vernier pulleys
- Hi flow fuel rail with stage two injectors plus wiring harness (I may not need these as I have a VXR fuel rail + injectors which looks like a better setup)
- Relocator kit for oil dipstick
I will run it off my Emerald ECU.
Edited by speedster, 23 April 2007 - 03:28 AM.
Posted 23 April 2007 - 03:46 PM
Posted 23 April 2007 - 03:55 PM
Edited by JamesGray, 23 April 2007 - 03:55 PM.
Posted 23 April 2007 - 04:39 PM
Posted 23 April 2007 - 05:02 PM
Posted 23 April 2007 - 07:34 PM
Winstar, on Apr 23 2007, 17:39 , said:
I hope this is going to be a well documented exercise
Are you using the block that Dude had with the low comp ratio pistons and what boost level do you reckon you'll be able to run?
I'd love to do my own SC conversion but like James I'm I bit unsure of the mapping, esspecially with a boosted application, wish I'd made more of an effort to get a secondment to calibration when I worked at Lotus now. How easy do you reckon it'll be to map?
The stage two pulley, I'm told, is good for 10 PSI. There is the option of smaller pulley which will give 14 PSI.
This is the engine setup I'm getting from dude and the above PSI figures are probably on the lower end of the possible scale.
- Std 2,2l engineblock with oilsump
- Eagle Cr-Mo Crank
- Eagle Cr-Mo rods
- Wiseco Pistons (8:5:1 if I recall correctly, dude?)
- Clevite rod and mainbearings
- ARP Headstuds
- SAAB cylinder head with turbocams and valves (yummy!).
- SAAB Std multilayer headgasket.
JamesGray, on Apr 23 2007, 18:02 , said:
Of course the other option is to build it up and then flat bed it to a mapping outfit, preferably one with experience and leave it with them for final mapping.
I think I might junk the ETB while I'm at it.....
I'll be keeping you all up to date on progress via my blog.
Edited by speedster, 23 April 2007 - 07:43 PM.
Posted 23 April 2007 - 09:03 PM
Posted 23 April 2007 - 09:18 PM
Edited by Ricky2772, 23 April 2007 - 09:21 PM.
Posted 23 April 2007 - 10:16 PM
paulf-cam, on Apr 23 2007, 17:11 , said:
JamesGray, on Apr 23 2007, 22:03 , said:
Surely a standard engine could take the same set-up?![]()
the 243bhp coutenay converstion uses all std internals
The rods were changed to allow for piston cooling things and there is a thicker head gasket... IIRC
So are new rods included in the Courtenay SC stage 2 then? I don't see any mention on their website of this?
Makes the £5500 seem a little easier to swallow if so
Posted 23 April 2007 - 11:16 PM
Ricky2772, on Apr 23 2007, 22:18 , said:
stock rods won't hold above 220hp... stock pistons are fine up to 250hp...
so, forged rods are a must.
make sure u get proper piston rings...i am at the 2nd "pistons out " due to wrong parts+wrong installation... now hitec is working the issue out... compression perfect, wrong oil rings it seems... all this on decomp JE pistons...
Interesting. I know the 2.0L SC engine has a different ring configuration. The top ring is slightly lower that the 2.2L. Wonder how them Wisecos are setup?
Posted 24 April 2007 - 12:49 AM
Quote
a good point would like to find out their opinion on this....
Posted 24 April 2007 - 01:03 AM
Posted 24 April 2007 - 02:31 AM
I always thought it was the rpm that killed the con rods, that's why courtenay's keep the standard rev limit for there conversion.
Edited by Winstar, 24 April 2007 - 02:31 AM.
Posted 24 April 2007 - 03:21 AM
I am still on standard rods and 242bhp, 6400 rev limit but seems ok I am in the process of getting Eagle rods/pistons as the £$ is good I would like 300 bhp
Posted 24 April 2007 - 03:26 AM
Posted 24 April 2007 - 03:40 AM
NickB777, on Apr 24 2007, 04:21 , said:
I am still on standard rods and 242bhp, 6400 rev limit but seems ok I am in the process of getting Eagle rods/pistons as the £$ is good I would like 300 bhpso probably 7500 rpm rqd but some more work required on the engine, crank?/larger pistons? new ecu all help appreciated
Sounds like where I'm heading
Nick, could you do me a favour, post a picture of your engine bay SC chargecooler connections, and front chargecooler core mounting, if you can.....
Edited by speedster, 24 April 2007 - 03:46 AM.
Posted 24 April 2007 - 03:55 AM
Sounds like where I'm heading![]()
Will do, BIG difference is the chargecooler in the front, it gets all the airflow / love the sound who needs a wife
