Posted 11 May 2007 - 12:50 PM
Posted 11 May 2007 - 12:57 PM
Posted 11 May 2007 - 01:53 PM
Good to see that it has arrived safe
Sorry about the dirty/old camcover, but i couldn´t get my hands on a new one![]()
Posted 11 May 2007 - 01:55 PM
Edited by atlesc, 11 May 2007 - 01:56 PM.
Posted 11 May 2007 - 02:01 PM
I couldn't resist the force no longer my self. No DIY operation for me, but the deposit is payed, I'm booked in at Cortenays at the beginning of July. OMG what have I done???
A momentary lapse of reason? Oh well
-Atle.
Posted 11 May 2007 - 06:55 PM
Edited by atlesc, 11 May 2007 - 06:56 PM.
Posted 14 May 2007 - 11:00 PM
Nope, just the standard stage 2 package as described on Cortenays webpage. I expect
they know what they are selling. You UK guys got it easy
. To deliver the car I have to
drive from Oslo to Bergen (600km), then take the friggi'n ferry (as Dr. Evil says on my GPS) to New Castle,
then down to North Walsam, deliver the car, stay over one night, fly home, wait 2 weeks, then fly back down to fetch the car. (After that I'm driving home the long way and visit the french 2500km).![]()
Atle.
Posted 15 May 2007 - 01:38 AM
Atle.
Posted 15 May 2007 - 12:08 PM
Atle.
Why don't you get the conversion done in germany by the company who invented the package, Hi-tec?
Posted 15 May 2007 - 12:50 PM
that question was answered on www.z22se.co.uk as : yes they could, but not sure on priceBtw, any idea if Courtenay sell the package as a kit?
Edited by vocky, 15 May 2007 - 01:06 PM.
Posted 15 May 2007 - 01:26 PM
Posted 16 May 2007 - 01:33 AM
Edited by atlesc, 16 May 2007 - 01:35 AM.
Posted 16 May 2007 - 02:58 PM
Posted 16 May 2007 - 04:21 PM
Posted 16 May 2007 - 04:34 PM
I am now in search of a new exhaust mainifold 4-1 short, large diameter
as per this article clicky
The Supercharger headers, on the other hand, can achieve 240 ft/sec quite quickly from the boost and don't need scavenging from the header-cat-exhaust system to generate this exhaust flow speed. They need an exhaust system which will efficiently remove as much of the combusted , inert exhaust gas out of the cylinder as possible. So SC headers tend to be much larger in diameter, shorter, a 4-1 layout, and have huge 3 in. collector.
any ideas where to find or get one fabricated
Edited by Winstar, 16 May 2007 - 04:39 PM.
Posted 16 May 2007 - 04:53 PM
What cams are you running with Nicky?
Typically you want nice long branches on the header to stop cross-cylinder pressurization. An example is the RKSport header with 16 inch branches CLICKY It's also got secondaries which will help broaden the power band. Though you'd need to find out what cam setup this system is targetting.
If you have standard cams you basically want a good flowing header with long enough branches to prevent any back flows (which rules out the standard exhaust manifold). As mentioned 4-2-1 will broaden the power band If you want more top end go 4-1 (same principles as NA engine). One rule of thumb I've come across is to make sure the branches are at least 12 inches long. Changing branch lenght will alter what level of power is delivered where on the power curve.
If your working with none standard cams things are a little more complex as your moving into the pulse tuning arena. Diameter of the header pipework is somewhat 'fixed' to cylinder size and the profile of the cams your running, as in these attributes determine gas velocity and pulse speeds, meaning for a supercharged engine, if your camming, what's proven to be good on an NA cam setup can be good for the blower setup.
If you want to go into the finer details you need to understand the impact the collector configuration has on the setup (tapered or terminated primaries).
Edited by Winstar, 16 May 2007 - 04:58 PM.
Posted 16 May 2007 - 06:11 PM
Posted 16 May 2007 - 06:19 PM
Posted 16 May 2007 - 06:46 PM
Interesting you think long 450 collector and not short, I was hopping to get away with just the top manifold replacement and not have to od further down.
Edited by Winstar, 16 May 2007 - 06:48 PM.
