Fitting the ProAlloy Charge Cooler
#81
Posted 05 June 2009 - 11:10 AM
#82
Posted 07 June 2009 - 05:44 PM
#83
Posted 08 June 2009 - 02:37 PM
#84
Posted 08 June 2009 - 02:39 PM
#85
Posted 08 June 2009 - 02:58 PM
wire them into the fuel pump
For the switched live and ground? Anyone got any wiring locations/colours for them?
electrics are not my strong point
#86
Posted 09 June 2009 - 08:01 AM
#87
Posted 10 June 2009 - 08:58 AM
#88
Posted 10 June 2009 - 09:57 AM
No wonder I couldn't see how the pre-rad was going to fit in on top of the standard rad. On the NA there are 2 plastic sections bonded onto the crash structure which need to be removed. Otherwise there isn't a hope of fitting the prerad.
These two bits aren't present on the Turbo.
Yep, you need to take these off (discussed earlier) but you then need to support the rads on some hardish foam. The plastic rad supports bear the weight of the rad. The radsurround is rubbish material so wont take the weight o the rad bouncing around. The standard tubby has closed cell foam which people cut down to fit the CC rad. How are you getting on?
#89
Posted 10 June 2009 - 10:08 AM
#90
Posted 12 June 2009 - 03:18 PM
#91
Posted 12 June 2009 - 03:24 PM
#92
Posted 12 June 2009 - 05:10 PM
#93
Posted 12 June 2009 - 06:32 PM
#94
Posted 12 June 2009 - 07:07 PM
#95
Posted 10 November 2013 - 08:01 AM
#96
Posted 09 December 2017 - 08:04 AM
#97
Posted 15 December 2017 - 01:47 PM
If you go here http://www.courtenay...n/info_117.html and look for Vx220 charge cooler fitting, a lot of the pictures in the guide are ones that Courtney's 'took' from my guide before the links were lost.Does anyone have a pdf version of the installation? Photobucket ruined this thread...
