New Larini Group Buy
334 replies to this topic
#221 mikemph
mikemph
  • 340 posts
Posted 16 June 2007 - 06:32 PM
Same it's all fitted, what a sound, best mod so far. I would say to anyone fitting it themself to get a mate to hold some of the parts while bolting it on. Can be tricky on your own. Mine is on but one thing I noticed when fitting was that my old brakets were bent I thought nothing of it being a hand built car. So rather than messing about bending the new one the same I used the old ones. Anyway just browsing Larini website for price for cat section, and I noticed the brakets in the picture are on opsite sides, ie left on right vice-virsa, hence why the old brakets were bent. Some one put them on the wrong side last time. So tomorrows job is to go fit the new ones on the right sides. So boys and girls, thats a little tip for you all to check when it arrives that the bracket are bolted to the correct side, they may be on the wrong side when they arrive. I stupidly assumed they were on the right sides, even though they were only on loose.
Edited by mikemph, 16 June 2007 - 06:35 PM.
#222 justin182
justin182
  • 621 posts
Posted 17 June 2007 - 09:47 AM
do you need a new gaskett if you are just fitting the backbox? i know you need one for the precat. did you just use the original bolts? or anyone know what size they are so i can get new ones :)
#223 mikemph
mikemph
  • 340 posts
Posted 17 June 2007 - 11:50 AM
I used new bolts, went and bought M10x50 and M8x50, you will need to use the M8 ones if you are using the OEM cat. I think really M8x40 would be fine though mine were a bit long. If you use the larini sport cat I am pretty sure you could use M10 as they fit in the holes on the flange. I did use a gasket, the same one as the precat on the VXT (the part number on the bag is 1#13101735). I used stainless bolts, washers and nuts as I will be getting a sport cat at some stage and didn't want to chisel off the old one again like I had to do with the OEM exhaust. As for the bracket they were on the wrong sides, the tailpipe sit in the bumper gap much better now. The offset on the bracket was about 1" so by swapping sides it made an overall difference of about 2" (so check your bracket agains't the picture on larini website. They have them on the right way in the picture on the website. It will save you alot of hassle :) Oh I think I have mentioned it already, sound lovely mmmmmmmmmmmmmm
Edited by mikemph, 17 June 2007 - 11:52 AM.
#224 justin182
justin182
  • 621 posts
Posted 17 June 2007 - 04:04 PM
ok thanks mike, your a star! just another question or two, how many bolts will i need? i have ordered the precat aswell, but think im going to leave this off for a while, get it done at a garage as i heard its really fiddley :) do vauxhall keep these gaskets in stock? probably not lol
#225 mikemph
mikemph
  • 340 posts
Posted 17 June 2007 - 04:29 PM
Is it a VXT justin? If it is it's well easy to do the pre cat!!!
#226 justin182
justin182
  • 621 posts
Posted 17 June 2007 - 04:38 PM
yeah mine is a turbo, is it easy to change then? you couldnt write a list of the bolts etc i will need? I take it i need 2 gaskets 8 M8/10 etc bolts Gun Gum ???
#227 mikemph
mikemph
  • 340 posts
Posted 17 June 2007 - 05:08 PM
Yep, you will need, (the length are what I have used but the 50mm ones could do with being shorter 40mm would do). 2x Gaskets 3x M8x35 for precat-to-cat 3x M8x50 for the cat-to-back box (M10 are tight to get through the gasket but will go through the bolt holes on larini) I haven't used gumgum doesn't seem to be leaking anywhere, and once it cokes up a bit that should seal any small leaks i hope. The pre cat has a v band clamp to hold it onto the turbo which I have reused with no problems. There is a gasket in there not sure what the number is for that. Vauxhall at kidlington had parts next day for me and the part guy there seem pretty switched on. I will find the invoice out later and find out what exactly length they gave me. You will need torx sockets to get the heat shield from around the pre cat area.
Edited by mikemph, 17 June 2007 - 05:17 PM.
#228 justin182
justin182
  • 621 posts
Posted 17 June 2007 - 05:10 PM
thanks mike, that would be great.. am going to phone larini tomorrow and see whats going on. Was meant to have it by now :( think i will go into VX and get the parts ordered!
#229 mikemph
mikemph
  • 340 posts
Posted 17 June 2007 - 05:12 PM
It will be worth the wait when you hear it, you will love it. I have edited the one above with what you need, and you will need nuts and washers. I used spring washers as well so the nuts don't vibrate loose. I'm sure they are not needed though
Edited by mikemph, 17 June 2007 - 05:19 PM.
#230 CheesyPuff
CheesyPuff
  • 415 posts
  • Interests:Dogging
Posted 17 June 2007 - 09:40 PM
Did you use a gasket between the turbo/precat pipe a ive heard some have them and others dont, Ive got a Magnex precat pipe that Im going to fit when I do the backbox and dont know if I sould get te gasket or not. Fitting th precat pipe isnt any real trouble then it would seem, I didthe backbox on my old NA so Im prepared for that but wasnt looking forward to the precat bit. hopefully the backbox will be this week as Im off on holiday on Saturday. Darren...
#231 justin182
justin182
  • 621 posts
Posted 18 June 2007 - 09:27 AM
should be here this week.. just phone dave and said they are just getting polished up now :)
#232 justin182
justin182
  • 621 posts
Posted 19 June 2007 - 12:59 PM
picked up my gaskets today, were £19.15 for two!! :o
#233 mja182
mja182
  • 1,129 posts
Posted 20 June 2007 - 01:44 PM
Anybody else got their larini yet other than mike?
1.mja182 (n/a back box) Ordered!
2.Denno (VXT back box) Ordered!
3.Cheesypuff (VXT back box)Ordered!
4.Meo (Full system)
5.madmoose? ((VXT back box) Still considering my options, will update asap
6.2kracing? (back box) Wants to wait but will go with the majority
7.bandedo (n/a back box) Ordered!
8. vx220pete? (VXT back box)
9. MY04VXT (VXT back box) Ordered!
10. Justin182? (VXT back box) Ordered!
11. mikemph (VXT Back box) Ordered! Arrived
12. antgtv (VXT full system with sports cat)
13.Alanvx (VXT back box)
14.Jigz (n/a back box) Ordered!
15. cthomas443 (n/a back box)
#234 justin182
justin182
  • 621 posts
Posted 20 June 2007 - 01:47 PM
nope, no sign here.. :(
#235 justin182
justin182
  • 621 posts
Posted 21 June 2007 - 09:26 AM
just phoned again, and not getting a good vibe off the guy.. sounded a bit dodgy.. took my number and said he would phone back today... :wacko:
#236 mja182
mja182
  • 1,129 posts
Posted 21 June 2007 - 10:32 AM
What do you mean by "sounded a bit dodgy" lol?
#237 justin182
justin182
  • 621 posts
Posted 21 June 2007 - 12:34 PM
i dont know tbh.. u know how u sometimes just get a 'feeling' lol.. fancy phoning and see what he says? im sick trying... :beat:
#238 wrightster
wrightster
  • 2,808 posts
Posted 21 June 2007 - 01:51 PM
Marcus whose are those backboxes in your garage at home ? you know the 15 of them ?
#239 mja182
mja182
  • 1,129 posts
Posted 21 June 2007 - 01:58 PM
Well i had a plan that i could buy them for £470 deliv. then sell them on at a silly price of about £700 and make a stonkin profit.
So thanks for the idea Paul thumbsup
I will have a VXR/Supercharger/Exige/Turbo, new house and 12 holidays a year in no time. :D
#240 wrightster
wrightster
  • 2,808 posts
Posted 21 June 2007 - 02:06 PM
Did you pay cash or credit card mate ? :P
