Spring Rate?
#21
Posted 28 November 2004 - 06:36 PM
VX220 Turbo = 275 / 315 lbs/in = 49 / 57 N/mm
VX220 Spax kit = 250 / 350 lbs/in = 45 / 62 N/mm
VX220 NA Nitron kit = 375/475 lbs/in = 68/ 86 N/mm
VX220 Turbo Nitron kit = / lbs/in =
VXR = 300 / 340 lbs/in = 54/61 N/mm
Oehlins = 350 / 400 lbs/in = 63 / 72 N/mm
S1 Standard = 185 / 220 lbs/in = 33 / 39 N/mm
S1 LSS = 228 / 285 lbs/in = 41 / 51 N/mm
S2 Standard = 228 / 285 lbs/in = 41 / 51 N/mm
S2 LSS = 250 / 325 lbs/in = 45 / 58 N/mm
#22
Posted 28 November 2004 - 07:24 PM
VX220 Turbo = 275 / 315 lbs/in = 49 / 57 N/mm (estimated value)
VXR = 300 / 340 lbs/in = 54/61 N/mm (estimated value)
Oehlins = 350 / 400 lbs/in = 63 / 72 N/mm (estimated value)
#23
Posted 28 November 2004 - 10:47 PM
#24
Posted 28 November 2004 - 11:04 PM
#25
Posted 01 December 2004 - 01:12 PM
#26
Posted 04 December 2004 - 04:41 PM
Do you think the 68/86 N/mm is too hard then? It seems that Lotusspecials have used 100/120 N/mm on race tracks successfully.I had my nitron n/a kit tested before they were fitted.
The fronts are 375lbs/in
The rears are 475lbs/in
Perhaps people can see now why I always whinge about how they are too hard for the road!
Anyone wanting nitrons please note - you can specify them with whatever spring rate you want. I just ordered the vx220 n/a kit and that is what I got.
Cant you just have a softer damping to compensate??
#27
Posted 06 December 2004 - 07:42 PM
#28
Posted 06 December 2004 - 07:47 PM
#29
Posted 06 December 2004 - 08:11 PM
#30
Posted 06 December 2004 - 09:48 PM
#31
Posted 07 December 2004 - 06:56 PM
#32
Posted 07 December 2004 - 07:46 PM
#33
Posted 07 December 2004 - 08:52 PM
I have Nitrons on my NA and after i fitted them and went for a drive out of work (mega bumpy B roads) i thought i had wasted my money as the car was a proper bone shaker and hard work to keep in a straight line.I had my nitron n/a kit tested before they were fitted.
After having it setup properly it is still a bit on the not so comfortable side of firm (but firmly planted to the road) on the lane but IMHO it is an improvement of the original setup as there is no wallowing (hard to explain) over dips and bumps anymore.
Obviously on smooth roads it has made a massive improvement.
I don't think i would go for a softer spring rate as the compromise seems pretty spot on to me.
I guess to hard for one person is someone else's to soft, as Barry said you can order the Nitrons with different spring rates which makes everyone happy, knowing what spring rate to order is another thing altogether though.
Edit;
I guess that is where steves and Clipping points spring rate table will help.
Edited by SamH, 07 December 2004 - 08:56 PM.
#34
Posted 07 December 2004 - 10:35 PM
#35
Posted 08 December 2004 - 07:32 AM
#36
Posted 08 December 2004 - 10:22 AM
#37
Posted 11 January 2005 - 01:09 PM
#38
Posted 11 January 2005 - 01:49 PM
#39
Posted 11 January 2005 - 03:26 PM
...at least I think so??
#40
Posted 11 January 2005 - 03:35 PM
