Grade 10.9 Socket Head Hub Carrier Bolts
163 replies to this topic
#161 Winstar
Winstar
  • 4,264 posts
Posted 21 January 2008 - 10:27 PM
Winstar - Do you want to do another group buy?
The reason I ask is Spitfire Engineering just e-mailed me offering to do a similar thing but with the bolts plated. The plating is done per batch and as they get a lot of stuff done, including the tie rod kit brackets and bolts a whole load of extra bolts chucked in the plating tank won't make any difference. Shall I get a price?
Er no not after the hassel the last one was.
PS, the real problem is not so much in the bolts themselves but in the camber shims and the ABS bracket.
You have two coarse lumps of iron which are bolted together sandwiching shims which could be better finished and have a larger surface area. I'm having a set of stainless modified camber shims made up to go with my aluminium hub carriers (eventually) and aluminium steering arm mount (sooner) :)
Coincidently I've just been on a bolted joints course by Bolt science and yes the most likly cause is that each of the intefaces, esspecially rough ones like a cast surface, effectivly causes a loss in the camp force applied by the torque.
#162 Sutol
Sutol
    Well it's nearly a Lotus
  • 8,122 posts
Posted 21 January 2008 - 10:29 PM
12.9's no, 10.9's yes according to PMS.
#163 Muncher
Muncher
  • 4,494 posts
Posted 12 February 2008 - 08:55 PM
After swapping another set of these for uprated ones I feel they can be improved further with deeper torx heads to stop them from rounding off, so watch this space ;)
#164 Muncher
Muncher
  • 4,494 posts
Posted 14 February 2008 - 01:14 PM
Got a price of about half of what you guys paid for long head zinc plated bolts. They're investigating Torx headed ones for me as I think they'd be a big improvement, but I'd need to get them from America I suspect.
