Changing the VXT Cam Belt
49 replies to this topic
#21 Lps
Lps
    Team 600+
  • 3,375 posts
Posted 06 February 2009 - 02:28 PM
*bump* for Chris
#22 starlight
starlight
  • 1,790 posts
  • Interests:Oily bits...
Posted 07 April 2011 - 10:08 AM
Full PDF version of original guide with all the pictures now on the WIKI site:
wikisite cam belt change with pictures
#23 mbes2
mbes2
    Someone say Plasti Dip?
  • 8,516 posts
    "Yes, I built it"
Posted 20 June 2012 - 03:47 PM
just found this video.... kinda give you the idea....
#24 siztenboots
Posted 20 June 2012 - 03:51 PM
change the water pump at the same time
#25 Duncan VXR
Duncan VXR
  • 5,281 posts
Posted 20 June 2012 - 03:54 PM
Belt change on let/leh is very straight forward tbh. Some horrible engines out there to
#26 mbes2
mbes2
  • 8,516 posts
    "Yes, I built it"
Posted 21 June 2012 - 06:49 AM
I'm currently reading up on the steps, for next years service.... looks like access is good
#27 hutchy
hutchy
  • 429 posts
Posted 22 June 2012 - 04:28 PM
They make that look pretty easy on an astra, is access much harder on a vx?
#28 out on the bike
out on the bike
  • 447 posts
  • Interests:fast bikes and fast cars
Posted 23 June 2012 - 02:33 PM
Access is actually not too bad on the vx with the wheel arch and top engine mount removed.
#29 aKra
aKra
  • 109 posts
Posted 20 February 2013 - 05:05 PM
I'm trying for two days now to get the tensioner to actually make some tension... It is impossible to get it to the "new belt" mark... Any clues? (Yes, I have done it counter-clockwise, but even clockwise wont do jack sh..)
#30 redvts
redvts
  • 1,472 posts
Posted 20 February 2013 - 05:56 PM
Water pump in the correct position? Are you sure you are letting the tensioner fully out?
#31 MrGman
MrGman
  • 735 posts
Posted 20 February 2013 - 06:18 PM
Make sure you don't push the allen key through into the blue plastic part. If you have pushed allen key in so far that it locates itself and lock into the blue ring it won't tension the belt.
#32 siztenboots
Posted 20 February 2013 - 06:54 PM
belt goes round bottom crank , then tensioner , then water pump, up past rollers , over cams, then back down
#33 aKra
aKra
  • 109 posts
Posted 21 February 2013 - 12:52 AM
Tryed all ways possible with the belt, i've read some things on the Internet about the waterpump that is "moveable" so I guess that is the thing then... Exactly the same belt that came off is going on. And the tensioner went all the way out, since after u turn it some more it retracts it selves again ;)
#34 siztenboots
Posted 21 February 2013 - 08:15 AM
sounds like water pump not located correctly, the lug on the casting should point to the about 11 o'clock, to a bump on the cambelt cover and block
#35 siztenboots
Posted 21 February 2013 - 08:37 AM
this picture shows the lug on the tensioner and the where it should locate to
#36 aKra
aKra
  • 109 posts
Posted 21 February 2013 - 06:13 PM
It was the waterpump that was out, thought the pulley was centered. My guide that I used (the PDF one) did not state this haha! Now all well and on the "new belt" mark... Just waiting for my new spark plugs, my new coil so I can start the damn thing back up ;) Thanks lads! (By the way, the cut out is a bit different on my/our block than what the picture showed, but I realised this was of great importance to make the tensioner work haha :happy: )
Edited by aKra, 21 February 2013 - 06:16 PM.
#37 jayworth2
jayworth2
  • 73 posts
Posted 11 April 2013 - 11:38 AM
I cant see anywhere this question has been asked. There is 2 cambelt kits listed one is for pre 2003 (93174265) which has the earlier 2 nylon tensioners and the other one later post 2004 (93185844) which has 1 metal tensioner & 1 nylon . Although mine is a 2004 model Autovaux said I had the earlier kit. I wanted to ask could I put the later kit on consisting of the 1 metal & 1 nylon?
#38 Ormes
Ormes
  • 4,612 posts
Posted 14 September 2018 - 06:03 PM
Useful bits of the information here that all help to build the picture :)
https://www.courtena...z20lex-engines/
thumbsup
#39 LeoD
LeoD
  • 53 posts
Posted 27 October 2018 - 06:01 PM
Can the water pump be changeed when doing the belt without removing the rear clam.  Building myself up to do this as the belt has not been changed since new!
Edited by LeoD, 27 October 2018 - 06:01 PM.
#40 ditonics
ditonics
    Turbos aren’t as good as NA’s
  • 939 posts
Posted 27 October 2018 - 06:06 PM
Yep
