Rear Clam Removal Guide
#21
Posted 17 December 2003 - 07:46 PM
#22
Posted 17 December 2003 - 07:49 PM
#23
Posted 25 November 2004 - 10:25 PM
#24
Posted 26 November 2004 - 05:55 AM
Edited by Ricky2772, 26 November 2004 - 05:56 AM.
#25
Posted 26 November 2004 - 07:45 AM
#26
Posted 26 November 2004 - 01:19 PM
#27
Posted 28 November 2004 - 09:11 AM
It seems the actual direction is "from inside the cockpit, towards the wheelhouse" in the next piccy
Correct??
....sorry that screw does not exist in my car, after the crash. It seems they have glued that part together!!
Edited by clipping_point, 28 November 2004 - 09:12 AM.
#28
Posted 28 November 2004 - 07:21 PM
#29
Posted 28 November 2004 - 07:31 PM
#30
Posted 29 November 2004 - 08:02 AM
#31
Posted 29 November 2004 - 03:23 PM
yes, it would obviously point toward the wheel... once inserted, the threaded part of the bolt would come out from the hole...And you agree that you point the screw in the wrong direction in your piccy??
#32
Posted 29 November 2004 - 03:40 PM
#33
Posted 29 November 2004 - 04:24 PM
problem is that drilling from the cabin is pretty much impossible, due to tight quarters...I might try to restore the bolt and hole. The clam is new so there is a thread in it that can be used if I drill a hole from the cabin.
you should ask them WHY they did it...it defies logic...
#34
Posted 29 November 2004 - 04:29 PM
#35
Posted 30 November 2004 - 09:21 AM
translated:They said that it provided a good somewhat flexible bond.
they lost the screw, so, quick solution needed...let's slap a good handful of glue in between parts...voilà!
did you ask them: I neeed to remove clam for mechanical work...how do I do it now, instead of 60 seconds-undoing the 2 bolts?
#36
Posted 30 November 2004 - 09:32 AM
#37
Posted 22 May 2009 - 09:22 PM
- Rear clam = Rear bodywork
- Front clam = Front bodywork
Great to have these kinds of guides - will defenitely contribute when I get my hand of a good specimen car
Reason I am asking is since I am about to bouy an Opel Speedster (probably Turbo) OR a Lotus Elise (R1 hopeully).
The Opel I am looking at says it has a "DAMAGED FRONT CALM" (guess he means CLAM) but says it is totaly repairable.
Is this true, or is there a risk of the frame being damaged?
Says he have driven into a "deep garage" and I guess he has knocked the bottom of the car into the floor due to the steep angle.
Something i should be worried about?
Best regards
Boogieman
ps
Seems like allmost all pictures are missing the links - just a CROSS in my browser
ds
Edited by SE_Boogieman, 22 May 2009 - 09:22 PM.
#38
Posted 22 May 2009 - 09:29 PM
As an aside, there are some fellow hurdy gurdy speakers here (Swedish owners) - in case you want some local chums (if you haven't seen that already)
#39
Posted 01 February 2010 - 10:20 PM
#40
Posted 01 February 2010 - 10:43 PM
yes, can´t see the photos of the tutorial...
I need remove the rear body to change the exhaust manifold and repair some fiber parts
If you send me your email address I will send you the front and rear clam pdfs....
