Transform Na Lights To Turbo Lights.
96 replies to this topic
#41 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 11 September 2007 - 09:37 PM
Ye of little faith - you may mock...
...but
It only bloody worked :jump: :D
At 125 degrees the adhesive become 'stringy', but not quite enough, as below:
So cranked her up that little bit further to around 135/140, et voila:
Lens came straight off - no force required thumbsup
Even better, the black surround on the lens stayed intact, and the adhesive remained stuck to the light body, so easy to remove - very neat:
No visible deformation to the light at all, and the foam has stayed intact too! - May be best to put some foil over to disperse any direct heat tho :huh:
PS - I take NO responsibility for the consequences of anyone cooking their lights
and yes XXX, I have been :drink:
Edit - now we just need someone to test a headlight (to see if the lenses are good for 140 degrees :) )
Edited by mandarinvx, 11 September 2007 - 09:41 PM.
#42 XXX
XXX
    Invisible ex-VX owner
  • 4,471 posts
Posted 11 September 2007 - 09:39 PM
thumbsup :lol:
#43 Baron Von Scubadaddy
  • 6,644 posts
Posted 11 September 2007 - 10:09 PM
I Tell ya I've cooked a few things before .......... ya get me ? But never Fixed beam Headlamps Can't wait to do this I may even have a go tomorrow I knew that digital display on the cooker would come in handy This maybe the first time I Touch the Oven :lol: :lol: I may even put a few air circulation holes in as advised by another member Top work
Edited by scubadaddy, 11 September 2007 - 10:11 PM.
#44 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 September 2007 - 10:13 PM
If you have enough room in the oven, prob best to put a second baking sheet above the light - the elements in my oven are behind the interior plating, but some ovens have them exposed (so higher direct heat) and make sure you turn the fan setting on to get even coverage thumbsup
#45 Baron Von Scubadaddy
  • 6,644 posts
Posted 11 September 2007 - 10:15 PM
Is that the same one that Chris needs You should pass it on to him for guiding the light for now once there was Silver shall now be Yellow_Black Good Karma to send it to Chris I think Imnotworthy Imnotworthy Imnotworthy
#46 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 September 2007 - 10:21 PM
The lens already had a large corner section missing from it (from a previous [obviously failed] attempt at removing the lens with a scalpel) :( I wouldn't have experimented with a good nick tubby light :wacko: If you have a go, make sure you turn the temp up nice and slow thumbsup
#47 Baron Von Scubadaddy
  • 6,644 posts
Posted 11 September 2007 - 10:29 PM
and how long till she's done 20mins ? half an hour ?
Edited by scubadaddy, 11 September 2007 - 10:29 PM.
#48 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 September 2007 - 10:34 PM
Not sure about time mate, kept taking it out to have a play and then upping the temp
Was prob at around 130 for about 10 mins, but would be best to keep increasing temp from about 50 upwards and keep checking it (the last 10-15 degrees made all the difference)
Can't be totally sure how reliable/accurate the temp knob is on the cooker either (it's a 1980's jobbie! :beat: )
#49 james141
james141
    Whiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiine
  • 3,667 posts
Posted 11 September 2007 - 10:37 PM
mmm... tasty :blink:
:o :o :o :o :o :o
You guys are brave!! Imnotworthy thumbsup
Edited by james141, 11 September 2007 - 10:39 PM.
#50 Baron Von Scubadaddy
  • 6,644 posts
Posted 11 September 2007 - 10:47 PM
It's only plastic he he :P Silly question I know but how do the lights come out ? and a bit late in the thread :beat:
#51 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 September 2007 - 10:56 PM
Four plastic 'nut' type things accessed through the boot. The wiring harness has a plug that can be disconnected, make sure you remove the harness with the the bulbs/holders before attempting to cook it :) According to 'Engineering Laboratories inc', the melting point of PMMA is 160 degrees, so don't go above 140 thumbsup (prob should have done that research a little earlier)
#52 Karlosfandango
Karlosfandango
  • 437 posts
Posted 12 September 2007 - 09:45 AM
75-100 was enough to get mine off, definately start low and let the heat in the oven build up. I put mine in a cold oven and turned it to 75, checked them after about 8 minutes and they weren't quite there. So put it upto 100 and checked again after a few minutes, this was enough to slowly lift the clear cetion off.
#53 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2007 - 09:46 AM
happy cooking to all of you :P :P :P
#54 Crimson_Killa
Crimson_Killa
    Posting My Opinion
  • 2,962 posts
Posted 12 September 2007 - 10:08 AM
next... possibly carpet the interior and get HID's..
but thats it now. gunna save now for a turbo.
and lower it ;)
#55 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 12:00 PM
just popped a head lamp in :o
#56 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2007 - 12:02 PM
just popped a head lamp in :o [/quote] good luck with the cooking :blink: :blink: let us know :P :P
#57 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 12:19 PM
second one in at 100 first one came apart ok
#58 andyroo
andyroo
  • 994 posts
Posted 12 September 2007 - 12:31 PM
Will the original adhesive still be good enough to stick it back together again with?
#59 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 12:56 PM
No way I've got some aquaria seal I'm gonna give that a go
#60 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 September 2007 - 12:57 PM
No way
another receipe :blink: :blink:
