Transform Na Lights To Turbo Lights.
96 replies to this topic
#61 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 01:34 PM
old sealant is a bitch to getoff with out heat Gun :9mm: :flame:
#62 andyroo
andyroo
  • 994 posts
Posted 12 September 2007 - 02:01 PM
Put it in the oven? :rolleyes: :P
#63 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 03:20 PM
to be honest the oven may not be the best solution for the fronts there is quite a lot of metal in there I think my head lamps have been bodged repaired I've had a couple of bits have dropped off so re fitting could be interesting :poke:
#64 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 05:46 PM
all back together again
and looking much better .
pictures later
#65 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 07:11 PM
First off Thanks to Chris for making it possible for me to even think about doing this mod Imnotworthy
So used the Oven for the head lights
pre heated the oven to 100 put the head lamp in for 10 mins
this was enough to let me run a knife between the lens and lamp holder if I'd had a heat gun it would have been much simple to remove the previous sealant
Loads of scum in side
rubbed it down a bit first
a couple of coats and a flatten with a dry wet and dry fine paper
Then re sealed with aquaria sealant
Got them resting over night with abit of weight on them
re fix and re focus tomorrow .
:sleepy:
#66 chris_uk
Posted 12 September 2007 - 08:43 PM
oh yea, its getting lowered 25mm aswell :D i am thinking about taking all mine apart again and refitting them, just to make sure there are no sealing problems, i had NO condensation on the fronts today and normally i do when i wake up :) just need that other light. also scuba, i never sanded them down or anything :lol:
#67 Baron Von Scubadaddy
  • 6,644 posts
Posted 12 September 2007 - 08:56 PM
I just had to sand them I didn't have any primer. :wacko:
#68 Karlosfandango
Karlosfandango
  • 437 posts
Posted 13 September 2007 - 07:01 AM
One thing I did notice is that I appear to have weapons grade masking tape. The residue left from it on the inside of the lenses took forever to get off, which was handy :beat:
#69 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 13 September 2007 - 07:07 AM
re fix and re focus tomorrow . how the cooking :blink: :blink: :P :P
#70 Arno
Arno
  • 1,238 posts
Posted 13 September 2007 - 08:43 AM
Has het back of the headlight unit melted/distorted? Seems like your light units have drooped inside the housing on the shot above (may be angle of shot), especially the dipped beam projector lense seems to be resting on/behind the plastic?
#71 Baron Von Scubadaddy
  • 6,644 posts
Posted 13 September 2007 - 09:36 AM
lenses git moved around a fair amount whilst I was do the mod off to put them back in now :beat:
#72 Evad
Evad
  • 69 posts
Posted 13 September 2007 - 12:17 PM
This is brilliant the thought of VX owners accross the country cooking they're lights in the oven is priceless. I can just see it on Gordan Ramsay now.. Oven 100 degrees... VX220 Rear Cluster in, COOK 10 mins! VX220 Rear Cluster with lens removed.....DONE! :lol: My drivers side rear needs the glass taking out to get rid of the scum where i've had some water get in so i may well have to give this little trick a go. Must admit i'm rather scared i'm going to end up with a puddle of molten plastic and a few bulbs in the middle. Out of the people who have done this has anyone managed to deform they're lights at all?
#73 Baron Von Scubadaddy
  • 6,644 posts
Posted 13 September 2007 - 12:42 PM
It won't melt Id try 100 for about 10 mins Have a heat gun ready to help remove any sealant that didn't come off at first Make sure you mask both sides of the lens to make sure. You don't want to mark or paint it :beat: This is a really easy mod to do none should be scarred to do this one I spent a total of £18.88 on this mod Paint soft sanding block sandpaper (which you don't really need ) Masking tape 12 croc clips aquaria sealant Nice and simple one to do. thumbsup
Edited by scubadaddy, 13 September 2007 - 12:43 PM.
#74 chris_uk
Posted 13 September 2007 - 12:58 PM
thumbsup
says him who was petrified to try it lol
#75 Pulsatingstar
Pulsatingstar
  • 342 posts
Posted 13 September 2007 - 01:07 PM
Im too scared to try it too :( My ovens from about the 70s though, in gas marks that have all worn off. I normally only use max lol. Might give it a go at the weekend if its dry.
#76 Baron Von Scubadaddy
  • 6,644 posts
Posted 13 September 2007 - 02:31 PM
thumbsup
I know
I've gone all Jack Barkley
I'll be running around in a pair of Grey overalls soon with
rag hanging out me pocket . poof
Wack'um in the oven get the seal soft run a knife through the seal
use a heat gun to warm any remaining seal
as the unit cools down
I may even attempt the 2.4 manifold swap with out the use of a mechanic Imnotworthy
#77 SAPD
SAPD
  • 1,269 posts
Posted 07 November 2007 - 05:26 PM
What did people use to bond the clear light cover back onto the light unit itself? Is "Aquaria sealant" a strong enough adhesive to actually keep these from dropping off? Any other suggestions (preferably in the next 2 mins as I desperately need to get to a DIY shop before 6pm :( :( :( )
#78 Baron Von Scubadaddy
  • 6,644 posts
Posted 07 November 2007 - 05:29 PM
Yes it is strong enough
Mine have not dropped off
you must have a good key for the sealant to bond to
and at least 6 strong spring clamps to hold it all together whilst it drys
Edited by Baron Von Scubadaddy, 07 November 2007 - 05:39 PM.
#79 andyroo
andyroo
  • 994 posts
Posted 07 November 2007 - 05:32 PM
Scubbadaddy has had his stuck on with that stuff for a while now so it should be fine thumbsup
Tiger seal/Sikaflex also seems to do the job!
#80 i need nos
i need nos
  • 3,404 posts
Posted 07 November 2007 - 07:04 PM
is there anyone brave enough to colour code there lights! black or silver not included lol...
