P1171 - Fuel Supply System Lean During Power Enrichment
6 replies to this topic
#1 benw
benw
  • 7,806 posts
Posted 10 October 2007 - 08:35 PM
Any ideas what this fault code actually means?
I've also got P0170 (Fuel Trim Malfunction) and have no idea what it means.
I'm sure one or both of these is causing the misfire I'm experiencing but have no idea where to start.
And please someone tell me why my fan won't go off. It's driving me nuts!! :(
#2 Jase_MK
Jase_MK
  • 6,277 posts
Posted 11 October 2007 - 02:45 PM
It was doing that when I saw you at Bedford back in Feb/March. You not sorted it yet?! :D
While you're at it, what's P0141 Heater Circuit all about? Mine's doing that.
edit: Nice avatar. See what I did there?
edit edit: Sorry, back on topic now :rolleyes:
Edited by Jase_MK, 11 October 2007 - 02:50 PM.
#3 Guy182
Guy182
  • 4,459 posts
Posted 11 October 2007 - 02:50 PM
fan switch is probably buggered.
#4 SteveA
SteveA
  • 9,156 posts
Posted 11 October 2007 - 03:36 PM
P0141 Means your second lambda sensor (post cat) or the wiring that connects it to the ECU is broken .
ben, fan = limp mode.
I will check the TIS for you and let you know.
Edited by SteveA, 11 October 2007 - 03:41 PM.
#5 luna_s
luna_s
  • 1,934 posts
Posted 11 October 2007 - 03:39 PM
well the heater circuit part, which doesnt really affect anything
#6 SteveA
SteveA
  • 9,156 posts
Posted 11 October 2007 - 03:48 PM
Tis says there is a problem with your fuel pump. There are 26 possible reasons for this. You will have to do some testing to narrow it down. Start by removing the K18 relay (the ECU relay) and measuring the voltage between the brown socket connector and ground. The result should be greater than 11v. Let me know how you get on and I will give you the next test.
#7 benw
benw
  • 7,806 posts
Posted 11 October 2007 - 08:18 PM
:o We could be here some time!!
Should have some time to have a look at the weekend. Thanks for your offer. I have TIS somewhere round here but don't know where to start looking for it!
By the way, I've been told it's on limp home mode before but never worked out what that actually means or how to work out what caused it.
I think it was Bedford that started it to be honest! One of those problems that only came up every now and then so I ignored it but now it's constant.
Edited by benw, 11 October 2007 - 08:16 PM.
