Just do it and stop asking questions!
Posted 24 October 2007 - 07:03 AM
Posted 24 October 2007 - 08:37 AM
To try and put across how much more air the engine gets (the removal of the material allows more air in faster) idle was at 2000rpm until the ecu adjusted it back down to 800rpm.
Posted 24 October 2007 - 08:55 AM
Posted 24 October 2007 - 08:58 AM
Bear in mind though that when you disconnect wiring and stuff the ECU resets itself. When my ECU resets and is started up for the first time, it idles at about 2000rpm for a while until it adjusts itself back down to 750.
Posted 24 October 2007 - 09:26 AM
Posted 24 October 2007 - 11:58 AM
OK, I assumed you reset the ECU. Probably worth resetting it to be honest so it can learn all the new flow values from scratch with the spangly new TB.
I'll take a look at mine when I fit the new manifold, don't want to overdo it though and end up like MarkV...
Posted 24 October 2007 - 12:45 PM
Posted 24 October 2007 - 04:13 PM
Posted 24 October 2007 - 04:17 PM
Posted 24 October 2007 - 05:05 PM
Posted 25 October 2007 - 07:54 AM
Posted 25 October 2007 - 08:31 AM
You can remove fuse 8 for a while (about 45 mins usually does it, no harm in leaving it longer). Open the fuse box, there's two rows of fuses, count down from the windscreen on the outer row (nearer to the wheelarch) until you get to number 8. If you've got the right one, the engine won't start. When you put it back in teh alarm will be armed and start beeping because the bonnet is open so have your keyfob ready.
Alternative use an OBD tool to reset the ECU.
Will run a bit rough for a the first 20 miles or so and usually takes about a tank of fuel before it's fully back up to speed.
Posted 25 October 2007 - 08:48 AM
No, that's what I said. Runs rough for the first 20 (you said 20-30) or so miles and takes a full tank before it starts to feel normal, say 200ish, you said 300).
Is this just my car???
Posted 30 October 2007 - 07:10 PM
Posted 30 October 2007 - 09:14 PM
Posted 30 October 2007 - 09:44 PM
Plan to do mine soon, just getting the gear together. Did you do the fuel pressure pipe mod, do you have standard air intake/exhaust?
Posted 31 October 2007 - 12:25 AM
Posted 10 November 2007 - 03:58 PM
Posted 10 November 2007 - 04:05 PM
andyroo did mine and top job the car is transform when i get the 2.4 manifold it will be even better lolGot mine in bits now, the butterfly vane sits at about 30 deg off horizontal and you can push it in each direction. is this 30 deg angle the idle position? Well at this position the vane seems to be sat right at the peak of the worst ridges, your drawing helps a bit but are we meant to not touch the bits when it it is horizontal or at this 30 deg angle?
This wont make sense LOL
Posted 10 November 2007 - 05:00 PM
