Porting And Polishing The Throttle Body
45 replies to this topic
#41 andyroo
andyroo
  • 994 posts
Posted 11 November 2007 - 06:17 PM
I just did the first ridge on the inlet only, the one well out of the way of the vane. Cant say I can tell a difference maybe a bit more popping and noise, not really had a proper go in it though. Was not confident enough to do the others, dont want to mess it up before the National.
the butterfly sits at an angle when the tb is off. If you trace a circle around the edge of the tb from a few mm before where the butterfly touches the tb shell at the shortest point and smooth to that line, you should be good. If you get me?
#42 vocky
Posted 11 November 2007 - 06:53 PM
just dont touch anything between where the butterfly sits and where it closes shut thumbsup
#43 Anarchy
Anarchy
  • 2,237 posts
Posted 11 November 2007 - 09:43 PM
Its hard to put into words, but I get the impression that from the vane being horizontal(when it is on the car) to about 30 deg the opening does not change because it follows a curved profile in the bore. If the vane simply sat at horizontal it would be straight forward to just grind the whole bore venturi style leading up to to the centre.
Anyway for a laugh I have done pic too, I removed the blue bit and was tempted to remove the red bitsPosted Image
Edited by Anarchy, 11 November 2007 - 09:44 PM.
#44 slindborg
Posted 12 November 2007 - 08:34 AM
In my experience its wise to NOT mirror finish anything in the inlet route as it ruins the boundary layer of air, which can then cause issues further in the flow (like fuel dropping out of suspension.... obv once its injected lol). a "sandblasted" type finish is a preffered one as it leaves a little area for turbulance on the boundary layer and keeps everything moving nicely. mirror finished exhaust side is fine though :)
#45 vocky
Posted 12 November 2007 - 09:06 AM
you can remove some of the red area, just keep a little further away from the butterfly swept area, plus the metal is a little thin on the lower red area :)
#46 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 12 November 2007 - 09:11 AM
thats what andy did to mine and good result well done
