We discussed two ways of doing it, one bracket with the capability to attach the brace should you want it or an additional bracket for the brace. I'll find out which method they went for next week when mine arrives. Either way if you order the full kit and the brace does not fit for whatever reason you can return just that part of it for a refund. I don't want people to be stuck if they find the brace does not fit because they have a particular exhaust or something.
New Tie Rod Kit Produced
Started by
Muncher
, Oct 23 2007 11:16 AM
82 replies to this topic
#81
Posted 22 November 2007 - 10:06 PM
#82
Posted 04 December 2007 - 06:36 PM
Can someone please take a photo of their outbound tie rod joint on a turbo, showing how much thread is above the locking nut on the hub carrier? Also if possible can you measure the thickness of the hub carrier at that point?
#83
Posted 06 December 2007 - 08:56 PM
Collets made to face against the slots on the face of the subframe for the tie rod kit for maximum contact, the other end is pressed into the rose joint.
Edited by Muncher, 06 December 2007 - 08:57 PM.
