Spitfire Engineering Tie Rod And Subframe Brace Group Buy
536 replies to this topic
#241 Marco Polo
Marco Polo
  • 268 posts
  • Interests:Cars and tracks :-)
    Roller skating in Paris
    Diving
    Wife and kids
Posted 17 February 2008 - 03:59 PM
installed !
no issue.
I've torqued the bolts 45Nm
What about the small ones ?
chinky chinky
#242 VIX
VIX
  • 9,497 posts
Posted 17 February 2008 - 04:17 PM
Sorry, not pics from me for a couple of months, just didn't want to miss the group buy. thumbsup
#243 Muncher
Muncher
  • 4,494 posts
Posted 17 February 2008 - 05:34 PM
installed !
no issue.
chinky chinky
I don't think the torque value on them is especially important, it can't be that high anyway due to the small size of the bolts.
#244 Sam3703
Sam3703
  • 120 posts
Posted 17 February 2008 - 05:40 PM
indeed there's no importance... they have been "hand torqued" from experience. But I can measure the torque that I have put. 8-10Nm I guess I even would have put rivets instead of bolts in that place, they are more able to whistand the shear. pics to come when I have some time to extract them from the camera
#245 Phil T
Phil T
  • 540 posts
Posted 18 February 2008 - 07:07 PM
Both these kits still available?
#246 Muncher
Muncher
  • 4,494 posts
Posted 19 February 2008 - 01:33 PM
The toe link kit is (only a handful left), the brace bar you will have to pay a bit more for though.
#247 Sam3703
Sam3703
  • 120 posts
Posted 20 February 2008 - 10:08 PM
I've installed the left toe link tonight (last time it was the right one only) A little bit hard to drill the subframe due to the Cat being close, I had to remove the bolts from the cat to the elbow tube to gain some clearance but that's working. A little bit tricky to tighten the small upper bolts, to hold the nut you have to put 2 fingers deep inside the hole in the subframe... now that everything's installed I think there's really no space to put a brace of that so big diameter. a 20mm should go but with low clearance to the cat, the undertray & the engine mount. I'll take measurements & pictures :closedeyes:
#248 Muncher
Muncher
  • 4,494 posts
Posted 20 February 2008 - 11:23 PM
I drilled the holes near the cat by jacking the cat up slightly and using an extended drill bit. Unless you've got a cat section which is substantially different to mine I think you'll find the bar will fit using the methods we have in mind. The photos will be good for comparison :)
#249 VIX
VIX
  • 9,497 posts
Posted 21 February 2008 - 08:39 AM
I seem to have missed the bit about drilling holes! :o - but don't intend fitting my kit for a while anyway. Any pics of what's involved please?
chinky chinky
#250 Muncher
Muncher
  • 4,494 posts
Posted 21 February 2008 - 09:16 AM
It will be obvious when Sam3703 posts his pics, they're for the 8 small bolts which hold the double sheer brackets onto the subframe.
#251 VIX
VIX
  • 9,497 posts
Posted 21 February 2008 - 09:28 AM
chinky chinky
#252 MEAGY
MEAGY
  • 1,374 posts
Posted 21 February 2008 - 12:28 PM
chinky chinky
might fit mine later,if i dont i ill post pics tonight!
#253 The Knobs
The Knobs
  • 3,481 posts
Posted 21 February 2008 - 01:19 PM
cant find a phone number for spitfire, anyone know it?
#254 Sam3703
Sam3703
  • 120 posts
Posted 22 February 2008 - 05:40 PM
PM
#255 Sam3703
Sam3703
  • 120 posts
Posted 22 February 2008 - 06:02 PM
here we are - 2 toe links fitted - clearance for the brace bar measured
pics !
double shear bracket in line with subframe - indeed you need to drill the subframe. Don't be affraid of any loss of strength of the subframe, the holes don't do anything. I would just recommand, if one day you decide to remove the bracket (to go back to standard toe links), to keep the screws+larger washers tightened in. that will spread the strain around the hole.
I attached the bracket with a M8 bolt to the existing hole, just to keep everything in place while drilling
then drill with a 6mm diameter bit
then find a lady with lady's fingers to put & hold the nut & washer that far
fitted !
I've done no pics for the left side, but the difference is that you have to jack the cat up (undo the bolts at the left ouput of the cat)
NOW the clearance for the brace
configuration : 2.2 NA with stock exhaust
*** distance from the cat to a line between the screws head centers
1,2cm to the tube... too close !
3cm to the cat
should be better a little more far to the rear from the bracket
#256 Sam3703
Sam3703
  • 120 posts
Posted 22 February 2008 - 06:05 PM
*** distance from the cat to a line between the screws head centers - 2cm rear from the bracket's surface
2cm from the bracket
2,5cm from the cat
almost 2cm from the tube
should be clear from the undertray as well
so i think a 1in brace bar can fit... thats tight. but that fits
cheers
#257 Muncher
Muncher
  • 4,494 posts
Posted 22 February 2008 - 06:17 PM
Thanks sam, the pics are great! The path the bar will take is actually lower than the string, and further back. Off the top of my head I think about 10-15mm lower than the string and the same again further away from the subframe. Should give at least 35mm clearance from the centre of the bar.
#258 Spitfire Engineering
  • 755 posts
Posted 23 February 2008 - 02:38 PM
Sam can you take a close up of the outer mount please?
why is the bolt so low?
are there washers under the head???
#259 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 23 February 2008 - 05:49 PM
Photo's taken of toe link. I used a cut down broom handle to show that the exhaust would foul the subframe brace. The car is a VXT 03 with a Miltek exhaust.
#260 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 23 February 2008 - 06:07 PM
