Edited by Muncher, 01 March 2008 - 09:16 PM.
Spitfire Engineering Tie Rod And Subframe Brace Group Buy
#281
Posted 01 March 2008 - 09:16 PM
#282
Posted 01 March 2008 - 11:11 PM
#283
Posted 01 March 2008 - 11:39 PM
#284
Posted 02 March 2008 - 07:08 AM
#285
Posted 02 March 2008 - 10:20 AM
#286
Posted 02 March 2008 - 12:04 PM
#287
Posted 02 March 2008 - 12:47 PM
Keeping the geo is not a problem as you simply measure (with a vernier caliper if possible) the distance from the lock nut to the end of the exposed thread. I will swap the ones on my car with new ones having just geo'd it and am confident it can be reset exactly, to one hundredth of a milimeter. I'll post a full guide on how to swap them without altering the toe whatsoever when they arrive this week.
Cheers, Instructions would be handy.
MAXR
#288
Posted 03 March 2008 - 06:13 AM
#289
Posted 03 March 2008 - 07:54 AM
#290
Posted 03 March 2008 - 09:01 AM
Am I right in thinking that for those who have not fitted the kit we can just wait and the replacement ends will be sent out to us with return instructions?
Yup
#291
Posted 03 March 2008 - 09:14 AM
#292
Posted 03 March 2008 - 09:16 AM
#293
Posted 05 March 2008 - 04:58 PM
#294
Posted 05 March 2008 - 05:52 PM
Hi Paul,
How do we proceed for those of us overseas ?
Thanks.
Not sure on the logistics but the new parts will be couriered to you, if the brace bar brackets are done pretty soon, which hopefully they should the bits can go with the brace kits
#295
Posted 05 March 2008 - 06:54 PM
#296
Posted 05 March 2008 - 07:03 PM
#297
Posted 06 March 2008 - 12:14 AM
wow that's big news...
at least I've not done the geo yet.
how come can you say that .4mm play per rod is not noticeable and no new geo needs to be done after replacement
as a reminder, the toe-in adjustment tolerance is 20' (0,33deg), which corresponds to approx 0,5mm of length difference on the links (approx the value of the play you claim). even if I had a vernier caliper so long (which is not the case), I would not be confident with a replacement without new geo. Especially on that car so nervous from the rear wheels, and especially on the english roads...
Adjustment tolerance is what the suspension is set to and doesn't bear much resemblance to the movement you can expect in the system once in motion and under load due to compliance of the suspension bushes, give in the subframe, etc and that’s before you even get to the tyres!
The play is not open but may reach this figure under load, without load it is less.
Academic as they are all being replaced anyway ………..
Basic steps to maintain geo setup : -
Place a strip of plywood under the wheel that extends rearwards enough for you grip it and rotate the wheel with it, about 2 foot or so.
Slacken the small bolts on bracket right off and reduce torque on main chassis bolt to about 15ft/lbs. then do the same with the outer bolt. (This just reduces the force required to undo the bolt completely and avoids having to use force on the bolts which may move the suspension and/or the car).
Slacken the outer bolt so the nut is off the upright then gently rotate the wheel with the wood first one way then the other link drops and is hanging by the nut.
Check that the outer bolt can slide in and out of the upright freely. if not move the wheel so it can. This is the central position for the bolt when re assembling and will give a maximum error of about .2mm
Carefully remove the chassis bolt and remove the toe link, be careful not to move the car or suspension in the process.
Slacken the locknuts and remove the rod-ends and lock nuts.
Prepare the link by first fitting the locknuts until they touch the Nitrile boot then screw the rod end into the link.
Refit to the car with the chassis bolt first at 10ft/lbs
Offer the link up to the upright and twist the rod until the outer bolt slides freely into the upright. lock down to correct torque setting.
Lock down the inner bolt to correct torque setting and also the bracket bolts.
This will keep you within a few % of the original geo.
Please note this is just for the few who have had a geo done after fitting, for the rest you will need a geo anyway, though you can use the above to keep the geo you had if you wish.
The rod ends left last Monday and are due any time now.
#298
Posted 06 March 2008 - 08:13 AM
#299
Posted 06 March 2008 - 08:06 PM
#300
Posted 07 March 2008 - 11:50 AM
