Spitfire Engineering Tie Rod And Subframe Brace Group Buy
536 replies to this topic
#381 Sam3703
Sam3703
  • 120 posts
Posted 29 March 2008 - 07:47 PM
new joints installed chinky chinky old ones will be sent back to you in 1 week through your friend at MA if that's OK for you ? cheers
#382 Muncher
Muncher
  • 4,494 posts
Posted 30 March 2008 - 11:15 AM
cheers
Yeah sure.
#383 Muncher
Muncher
  • 4,494 posts
Posted 30 March 2008 - 11:17 AM
They appear to be a bit too snug :huh: I don't think they are sitting all the way in. The good thing is I can remove them again because it uses a bolt rather than the original method which required quiet a bit of work.
Do you have the size of the full collet so I can check how much is in by how much is showing. thumbsup
Are you sure you don't need an M12 turbo versioned collet?
#384 Sam3703
Sam3703
  • 120 posts
Posted 30 March 2008 - 06:47 PM
that should not be snug, but on my kit the lack of a chamfer on the large spacer was making the screw hard to pass through, try to see if all the sharp edges are removed on the holes the torque on the hub side should be 65Nm not 45 :closedeyes: and make sure you discard the nylstop nut each time you remove it, that must not be installed 2 times on safety devices - risks of becoming loose -> shear of the screw -> off the road -> ouch chinky chinky
#385 NickB787
NickB787
    Gone but not forgotten
  • 7,813 posts
Posted 31 March 2008 - 09:07 PM
chinky chinky
Cheers
I have a standard NA and I will check tomorrow when it is having a geo done. The collets were chamfered. 65 it is then. and thanks for the nut info.
#386 Ducati996Senna
Ducati996Senna
  • 815 posts
Posted 01 April 2008 - 03:04 PM
Received my new joints last weekend. Fitted with no problems. Thanks thumbsup Any idea when the subframe brace is likely to be finalised for a VXT with a Miltek?
#387 Muncher
Muncher
  • 4,494 posts
Posted 01 April 2008 - 03:16 PM
About 2.5 weeks. There will only be one version of the brace bar, which will allow the bar to be mounted 15mm lower than the tie rod kit and will be adjustable in 2 planes. It will go down as low as the subframe will allow it to mounted if you see what I mean... Will either fit, or it won't :)
#388 NickB787
NickB787
  • 7,813 posts
Posted 01 April 2008 - 05:12 PM
"Scared Stiff" said they were fine, today, so thanks to all at Spitfire eng, really appreciated
#389 severnless
severnless
  • 517 posts
Posted 01 April 2008 - 06:57 PM
Paul :) just to let you know that the replacement joints have arrived safe and sound and make it all look very well engineered B) also to say that even with all of the grief you and spitfire must of had with the other joints, it still is much appreciated!! ;) my cap is doft to both thumbsup Imnotworthy also any more news on the clams? :P cheers chinky chinky
#390 Muncher
Muncher
  • 4,494 posts
Posted 02 April 2008 - 09:45 AM
Paul :)
cheers
chinky chinky
Nick - That's great, the guys at Scared Stifff are really good :)
severnless - Working on it :)
#391 Sam3703
Sam3703
  • 120 posts
Posted 03 April 2008 - 07:30 PM
geo done ! :groupjump: I look at the results and... errrrrr... +0,05° left, +0,45° right .... :unsure: sh*t they've done the front wheels !! :angry: :angry: :ninja: (and I am about to change the rack rod ends so I don't care about the front wheels... :glare: )
#392 MEAGY
MEAGY
  • 1,374 posts
Posted 05 April 2008 - 05:28 PM
got my new ends on, will send the old ons back asap muncher (to spitfire). Hopfully doing llandow next sat so will give thm some abuse & see how they hold up chinky chinky
#393 Marco Polo
Marco Polo
  • 268 posts
  • Interests:Cars and tracks :-)
    Roller skating in Paris
    Diving
    Wife and kids
Posted 11 April 2008 - 08:40 AM
Hi Paul, Any news about our joints (2-20 and myself) ? 2-20 told me about the name error on the shipping... I have checked with my "concierge", no sign of anything for Marco Polo (anyway, the postman must have seen on his own that this name isn't listed on the building's mail boxes) :unsure:
#394 Muncher
Muncher
  • 4,494 posts
Posted 11 April 2008 - 10:18 AM
No, they've not come back here yet, not sure how long they would take to come back?
#395 2-20
2-20
  • 1,317 posts
Posted 15 April 2008 - 06:09 AM
If there is an insurance, it's going to be time to use it.
#396 Muncher
Muncher
  • 4,494 posts
Posted 19 April 2008 - 01:08 PM
Will speak with Spitfire on tuesday but if we're lucky we may have all the components next week :D
As an aside, this is why you need the brace bar...
Elise 111R subframe which is similar in construction but they have added the large box section at the bottom to brace it.
#397 Muncher
Muncher
  • 4,494 posts
Posted 21 April 2008 - 07:17 PM
Spitfire are collecting the finshed brackets tomorrow and are then taking them for plating and that's it :D
#398 jay_vxt22
jay_vxt22
  • 453 posts
Posted 22 April 2008 - 11:52 AM
since this gb has now ended is there a contact to get these from, ive since decided to run more power with r888's, cheers
#399 Spitfire Engineering
  • 755 posts
Posted 23 April 2008 - 08:26 AM
As the components were made especially for the VX series both the toe-link only kit and the full kit are currently available. :)
Contact Paul directly or U2U him.
Cannot comment on the prices though, the brace will definately be a lot more expensive as all the changes and re-modding left me with a loss :(
But they look gorgeous so I don't mind :)
Edited by Spitfire Engineering, 23 April 2008 - 08:27 AM.
#400 2-20
2-20
  • 1,317 posts
Posted 25 April 2008 - 01:20 PM
UP
