Posted 01 May 2008 - 04:45 PM
Posted 02 May 2008 - 05:55 PM
Posted 02 May 2008 - 11:40 PM
Posted 03 May 2008 - 11:08 AM
Posted 03 May 2008 - 12:51 PM
Posted 06 May 2008 - 02:28 PM
Ok Marco
Well I can sculpture the bracket around the damage repair though it means one bolt will be missing.
Meatloaf claimed two otta three aint bad but three out of four is better
Can you check how thick the repair sheet is including any welding though excess can be ground off if need be.
If you have opted for the brace that would be ideal as it a has a major fixing inwards of the main bracket that will stop the main bracket distorting inwards under heavy load.
Posted 06 May 2008 - 05:23 PM
Ok Marco
Hi Spitfire Engineering,
Tie rod finally removed with a lot of sweat and some blood !
Here are 2 pictures :
Pic1.jpg 36.65KB 10 downloads
Pic2.jpg 36.87KB 9 downloads
The repair sheet is 2 mm thick...
Thanks for your help...
Posted 06 May 2008 - 06:40 PM
Did you want the brace as well?
Posted 07 May 2008 - 02:38 PM
Not sure...
I am not persuaded it will fit my full Milltek exhaust system...
So far I have been using a quick cure made by Hitec (an aluminium flat (rectangle shaped) bar mounted between the 2 lower points of the subframe - bolted to the diffuser fixings)...
Posted 07 May 2008 - 02:49 PM
Interesting, when was that bar fitted in respect to the damage on the subframe?
Edited by Marco Polo, 07 May 2008 - 02:58 PM.
Posted 13 May 2008 - 10:03 PM
Edited by Muncher, 13 May 2008 - 10:03 PM.
Posted 19 May 2008 - 08:21 AM
Posted 23 May 2008 - 04:59 PM
Brackets are made and will be collected by Spitfire on thursday to be checked and sent straight to the polishers.
Posted 02 June 2008 - 05:10 PM
Posted 02 June 2008 - 05:21 PM
Posted 02 June 2008 - 07:16 PM
Posted 03 June 2008 - 07:14 PM
Posted 03 June 2008 - 08:07 PM
I'm confident enough to take the money now. Braces @ £100 each to those who said they wanted one before the cutoff, but that's at a substantial loss to Spitfire so the price will be more for the others. Plus the standard carrier charge which is £15 in the UK iirc and about £25 to Europe.
Posted 03 June 2008 - 10:31 PM
Paul,
Can you PM me how you want payment for the brace bar and if it does not fit (due to the 2bular exhaust) can I return it unused? I also need replacement tie rods as the first set you sent has substantial play, especially on one side.
Cheers
Max
Posted 04 June 2008 - 11:28 AM
Arranged BACs transfer
