Spitfire Engineering Tie Rod And Subframe Brace Group Buy
#521
Posted 10 July 2008 - 10:05 PM
#522
Posted 11 July 2008 - 04:52 AM
Edited by Marco Polo, 11 July 2008 - 04:53 AM.
#523
Posted 11 July 2008 - 09:43 AM
#524
Was that extra?they had to do a fair bit of jiggling on my Jimsan
Honest M'lud - no money changed hands, they were just nice like minded people who I happeend to meet at a party
#525
Posted 11 July 2008 - 10:11 AM
10. Using a 6mm drill-bit drill through the 4 small holes on each bracket. Too make this easier we recommend using a drill bit extension device such as the one made by Bosch and sold at hardware stores for approximately £15.
NB. If you are fitting the brace bar kit you only need to drill the two top holes on the bracket.
The min clerance hole diameter for a M6 bolt should be 6.4mm clicky so better to use a 6.5mm drill bit. And on the NA you can drill the exhaust side by unbolting the u bend flange and lifting it clear with a jack.
#526
Posted 11 July 2008 - 11:04 AM
#527
Posted 11 July 2008 - 01:17 PM
Edited by Muncher, 11 July 2008 - 01:18 PM.
#528
Posted 11 July 2008 - 02:00 PM
jarl's collets went today
techieboy's bolt went today
Tom Murtagh, Max Rice, Philippe Gacek and Ernie Wright's ones have a courier booked for monday.
Cheers Paul!
#529
Posted 14 July 2008 - 02:44 PM
Thanks Paul, much appreciated. It turned up at some point Friday or Saturday whilst I was at Goodwood.
#530
Posted 17 July 2008 - 10:27 AM
#531
Posted 17 July 2008 - 05:43 PM
Been told brace bar came today thanks Paul
#532
Posted 17 July 2008 - 07:35 PM
muncher... can you confirm you recieved my cheque for £150 with my french address.
cheers.
ernie.
Yep
#533
Posted 19 July 2008 - 07:40 PM
Sewell M J (paid BACS) £115/£135 due
Ernie Wright (cheque) ?
Member 220 (chaps) £125/£145 Due (sent with Marco Polo's Kit)
David Boulbes (sam3703) £125/£145 Due
L Meaney (MEAGY) (BACS) £10 due
K D Smith (BACS) ?
Marco Polo (Chaps) £125/£145 Due (along with "220's kit))
Dollen Mr K/Ipca (BACS) £115/135 Due
Tom Murtagh £115/£135 due
VXR37 £115/£135 due
Stands as follows, I really want it all sorted by thursday as I'm off on holiday then for 2 weeks
Paul,
On above list (K D Smith) but with no amount next to my name?
Can you confirm if i can still get the brace bar for £135 (including new modified brackets)
Kevin
Edited by Morgan9122, 19 July 2008 - 07:44 PM.
#534
Posted 05 August 2008 - 11:46 AM
#535
Posted 05 August 2008 - 03:18 PM
#536
Posted 05 August 2008 - 04:26 PM
#537
Posted 05 August 2008 - 07:48 PM
Meanwhile, from those of you that have fitted them, in particular the brace bar how are you finding them? I know there have been quite a few positive experiences, Steve Guglielmi at Scared Stifff has asked for a custom made version for his racing Elise for instance.
There were a few who were going to get a few trackdays under their belt with it, have those done so yet?
It'll always be very tight, best to try it and see. (offering it up doesn't take long at all)
There were a number of people who sent me pics saying they didn't think it would work with a Miltek etc but it did
Scared Stiff/Guglielmi Motorsport couldn't fit my brace bar unless it was on it's very lowest setting because it wouldn't clear the bottom bend of the Milltek. However at it's lowest setting it would have meant dropping the diffuser (TAT short) by at least 40-50mm to clear the bar. Dave at Scared Stiff spent a good amount of time on the phone to Spitfire, so top marks to Spitfire for technical support. Scared Stiff could have had some spacers machined locally to drop the trailing edge of the diffuser down, had I wanted to. But, I elected not to try and fit it, pending decisions about a 2Bular system and/or a new diffuser. So, they ended up drilling the holes in the subframe and elongated them to match the slots in the brackets so that I can do it in future. Was hoping the new "MMG" diffuser would work but having had a look at it, I'm not overly impressed by the quality of manufacture so won't be going down that route.
On the plus side, the tie rods fitted a treat and in conjunction with the new carrier bolts and geo, meant I could give the car the necessary abuse at the National, safe in the knowledge I was as well protected on the suspension front as I could be.
