...so looks like im going to need to get to the ignition barrel.
Have you checked it with an oscilloscope (or even just a multimeter)?
Shall I bring in the machine that goes 'PING!'
Posted 20 January 2008 - 09:31 PM
Posted 21 January 2008 - 08:48 AM
does the launch control sound like this?? or is this the type that cuts the spark instead of injectors?
Posted 27 January 2008 - 09:41 PM
Posted 28 January 2008 - 09:07 PM
buchos..
can you list the VXturbo colours for the wires?
also what you done re: the clutch pedal switch for the full throttle shift??
just paid for my unit, would be a great help
Posted 31 January 2008 - 07:11 PM
I'll fit dedicated wheel sensors in February. The Racelogic sensors have a very small tolerance (1mm) so I'll follow someone's advice and try Hall "Wheel speed sensors for gear tooth" sensors on all wheels:The racelogic system is great provided you're ECU doesn't detect a hard engine cut, at which point you'll go onto two or three cylinders (The ECU is detecting for misfires so when the traction control cuts the cylinders the ECU thinks its a failure so it cuts the injector to save against cylinder damage). No problem switch the engine off and restart and the ECU resets, however you'll have to go to a Vauxhall garage to have the fault code removed which is just a reset on the comm. Its only a problem when youre doing track days with very tight hairpins I found.
You can reprogramme the ECU to stop the detection altogether but i got round it by adjusting the levels.
Has anyone else experiened similar problems? and would fitting the VXR wheel sensors help?
Cheers
Ian
Posted 31 January 2008 - 07:13 PM
Posted 31 January 2008 - 07:14 PM
you sure you havent got poor electrical connections??I'll fit dedicated wheel sensors in February. The Racelogic sensors have a very small tolerance (1mm) so I'll follow someone's advice and try Hall "Wheel speed sensors for gear tooth" sensors on all wheels:The racelogic system is great provided you're ECU doesn't detect a hard engine cut, at which point you'll go onto two or three cylinders (The ECU is detecting for misfires so when the traction control cuts the cylinders the ECU thinks its a failure so it cuts the injector to save against cylinder damage). No problem switch the engine off and restart and the ECU resets, however you'll have to go to a Vauxhall garage to have the fault code removed which is just a reset on the comm. Its only a problem when youre doing track days with very tight hairpins I found.
Cheers
Ian
Supply voltage: 4.5-24 V DC
Supply current: 10mA (typ.) 20mA (max)
Output signal type: Sink
Maximum operating frequency: 100 kHz
Sensing distance: From 0.5 to 4 mm (have been told the work with some angle)
Operating temperature range: From -40 to +150 C
The output of these sensors can be fed into the Racelogic-TC no problem. Not sure how the sensors can be mounted close to the wheels. All the advice anyone can give me (with some pictures) is very welcome!
Think switching to dedicated sensors will solve 2 problems with the current set-up feeding the TC from the ABS wiring:
Problem A: TC Signal noise at low speed (up to 15-20MpH)![]()
problem B: ABS switches OFF with errors "ABS DTC C0045 LR Wheel Speed Circuit Malfunction" and "ABS DTC C0050 RR Wheel Speed Circuit Malfunction" every time the car exceeds 120MpH.
Problem A I can live with, setting the threshold for TC at the appropriate level. Dedicated sensors will give clean signals from the first movement of the car at any speed.
Problem B is unacceptable for me to handle specially since the brake bias of my car is very aggressive at the back and I need ABS to balance. Removing the additional wiring will get the ABS circuits back to as-it-was-before.
I'll post the results on this forum.
The dedicated sensors won't solve the engine cuts ECU detection problem. Updating the ECU is the only way.
Posted 31 January 2008 - 11:35 PM
where have you mounted the control unit on yours?
Posted 01 February 2008 - 10:50 AM
Posted 01 February 2008 - 07:52 PM
Yes. connections are perfect.you sure you havent got poor electrical connections??
dry joint where you have soldered?
Posted 01 February 2008 - 07:53 PM
Received some mail/PM the other day. It seems I'm not the only one with high-speed TC/ABS problems.
Posted 02 February 2008 - 09:41 AM
Because I'm not the only one having a problem at high-speed with TC-ABS does not mean that the TC is the problem. Not figured it out completely. Problem started after fitting the TC (RaceLogic). It is likely that any circuit added to the ABS sensor-system may have some impact on the ABS.is this a problem with the racelogic TC??
i have a kit coming next week.. dont want to have problems
Posted 02 February 2008 - 10:31 AM
Posted 11 February 2008 - 05:46 PM
Posted 11 February 2008 - 05:48 PM
you sorted the clutch switch yet buchos??
Posted 11 February 2008 - 07:42 PM
Posted 11 February 2008 - 09:21 PM
did you have to extend all your fuel injection wires?
Posted 11 February 2008 - 09:29 PM
I broke one wire on each injector and I used a multicore cable with 5 pairs, 4 pairs for the injectors.
Luckily the car is so small its only about 2m of cable.
Edited by Guy182, 11 February 2008 - 09:33 PM.
Posted 12 February 2008 - 01:04 PM
few other Q's if you will.. how did you mount the digi adjuster in the dash plate?
have you had to tie aload of cables up out the way for the diagnostic lead -> digi adjuster etc? quick look at the kit and it sems as though i have to connect the 3 wires for the slip adjuster, and then the rs232 from the digi adjuster, to the female rs232 -> white connector B on the racelogic unit.
did you take the top of your dash off to fit it all?
