Traction Control
#81
Posted 15 February 2008 - 01:02 PM
#82
Posted 15 February 2008 - 01:52 PM
ok cool. will stick to the original plan the same as yours then otherwise it means extending the serial connectors etc.
any advice re the cable to extend the injectors?
just looking at the clutch switch wiring diagrams and it has +12v going to it... the racelogic unit requires a switch that goes to gnd...
You will not go wrong with heavier cable, I measured out 5 pairs of cable longer than needed. Put each pair in a cordless drill, clamp the other end and put a loose twist in each pair. Mark them, 'inj 1 to 4' and 'spare'. Stretch all pairs out from a vice and tape (not cable tie, they're hard to feed through the grommets) every 300mm or so and you have a neat loom.
I followed the gear change cables through the centre console and up under the dash, and thats all the front to back wiring done
If you want a loom made up, PM me your address and I'll get one made and sent to you.
Above is my rationalisation for how I wired the RL. On mine the concentration of connectors is at the front, all in one place, dramatically shortening all the cables and connections. The normal way I guess is to put the ECU in the boot and run the ABS, Digi Adj etc up the centre instead. Either way works fine. If I did not have the digi adjuster it would have been done the other way.
#83
Posted 15 February 2008 - 11:47 PM
#84
Posted 16 February 2008 - 12:22 PM
#85
Posted 16 February 2008 - 03:33 PM
Edited by Guy182, 16 February 2008 - 03:40 PM.
#86
Posted 16 February 2008 - 10:38 PM
#87
Posted 16 February 2008 - 11:39 PM
#88
Posted 16 February 2008 - 11:45 PM
Edited by Guy182, 16 February 2008 - 11:47 PM.
#89
Posted 17 February 2008 - 05:55 PM
there are;n't too many people running RLTC though so not sure we will get much settings!
Centre Gravity will be installing my RLTC next week, once installed I will post the settings.
At present I have TD's 16 / 17" with TR1's.
#90
Posted 17 February 2008 - 06:13 PM
Edited by Guy182, 17 February 2008 - 06:14 PM.
#91
Posted 17 February 2008 - 07:25 PM
thanks lou1s
how long are centre gravity taking to fit it??
its not a couple of hour job IMO..
The actual connections to the electrics are the easy bit and probably take about an hour.
Its getting the cables from one end of the VX to the other and fitting the adjuster that took all my time.
In a 200SX or a Beemer I would have enough room under trim and carpets to plumb in a central heating system, but getting just eight wires up the centre of the VX is keyhole surgery and I nearly needed skin grafts afterwards.
#92
Posted 17 February 2008 - 07:32 PM
They estimate about 4-6 hours, but they are going to fully document the install, therefore it may take a bit longer.
#93
Posted 17 February 2008 - 08:43 PM
They estimate about 4-6 hours, but they are going to fully document the install, therefore it may take a bit longer.how long are centre gravity taking to fit it??
Hi Lou1e, I'd be really interested in seeing details of a pro install, particularly the map. VXR36 kindly sent me his map and I've pretty much been able to leave it at 10% for all conditions. He had reduced the percentage of slip and a few other things and as I'm running 16/17s I found it felt really good and I'm still using it. The only issue is if wet mode is selected the TC kicks in constantly.
#94
Posted 17 February 2008 - 09:58 PM
#95
Posted 18 February 2008 - 09:19 PM
all ive got to do now is put the pins in the connectors and cut into the injectors
#96
#97
Posted 19 February 2008 - 12:04 AM
Had to think about picture IMG_0734.JPG, that was handy being able to flip the car over like that
Secure neat cabling
Where is the diagnostic plug going, inside or under the bonnet?
#98
Posted 19 February 2008 - 09:05 AM
Secure neat cabling![]()
passenger footwell, near my OBD2 diagnostic one
#99
Posted 19 February 2008 - 10:22 AM
#100
Posted 19 February 2008 - 01:21 PM
