Traction Control
#101
Posted 28 February 2008 - 03:45 PM
#102
Posted 28 February 2008 - 04:07 PM
sure i keeping getting a little misfire during normal driving: when at low revs and then decide to acclerate
i.e. at junctions/speedbumps/mini roundabouts
An LED that comes on when the TC is activated rather than flashing all the time would be useful.
I find I'm conscious of the TC when driving, waiting for it. On the standard map I can run as low as 5% all the time and notice some misses, at 10% I start to wonder if it is working at all.
#103
Posted 28 February 2008 - 05:57 PM
#104
Posted 28 February 2008 - 10:20 PM
this was set around 4%...
have you noticed any misfiring during normal driving?
Not while driving at a constant speed, but I'm sure it gives the odd miss during acceleration on lower % settings. At highest settings it does not miss at all.
#105
Posted 05 March 2008 - 09:06 PM
#106
Posted 05 March 2008 - 11:17 PM
#107
Posted 06 March 2008 - 08:31 AM
Very good stuff guys.
I haven't fitted the clutch switch myself, but I do know that there is an option in the software (the pc configurator thing), to "invert clutch switch". Don't know if that will help, but it may be a way for you to avoid having to make a clutch switch.
I have my TC ecu behing the passenger seat now (instead of tucked away in the boot) - I like to remove it if I'm going to leave the car anywhere dodgy (£500+ bit of kit not covered under like-for-like ins)... Also has the nice effect of totally imobalising the car too![]()
Oblomov, I have a monitor situated in the same place as that. I could only use quite thin alu to make the mounting bracket because thicker would push the dash up and make it wonky, so it wobbles quite a lot. Does your's? If not, do you have any tips for making it more stable.
Cheers
Richard
rik there is already a clutch switch on the car
the invert just changes it betwen normally open/normally closed.
it still needs a ground whereas the standard one switches a 12v. so a relay has to go in there.
#108
Posted 06 March 2008 - 08:16 PM
#109
Posted 15 March 2008 - 08:55 PM
Any tips on how to remove that gear/handbrake tunnel? Hope it doesn't take me as long as getting the dash off
#110
Posted 15 March 2008 - 09:08 PM
first of all you want to be able to get your gearknob off, i went out and boguth a baby boa from B&Q for like 7 quid. gets it off easy without marking it.
then two allen grub screws under the handbrake handle to take that off.
one screw clip at the top of the drinks holder, remove and the drinks holder lifts up
then you just got like 2 at the side.
then pull it up and push it forward to pull the suround round the handbrake lever.
http://guysleeman.co.../vxt/racelogic/
Edited by Guy182, 15 March 2008 - 09:09 PM.
#111
Posted 15 March 2008 - 09:48 PM
#112
Posted 16 March 2008 - 07:16 PM
#113
Posted 16 March 2008 - 08:31 PM
#114
Posted 16 March 2008 - 09:22 PM
#115
Posted 17 March 2008 - 10:15 AM
#116
Posted 17 March 2008 - 06:02 PM
yeah but when you log the graph it stays as the default assignment so just ignore the location it says and just pay attention to the channel number
if your off this week i'll probably be driving past sheff in the afternoon when i pick my car up from wolverhampton if you need a laptop to use
i use a usb>serial adaptor from maplin
Back at work for the rest of the week unfortunately, but thanks for the offer.
I've had some results today, confirming that all the sensors work and can pick up wheel speeds, although I'm back to three at the moment. I suspect either my dodgy wiring or the earthing problem. Not had a chance to connect the shielding to the battery yet but will next weekend.
Biggest problem at the moment is that the software on my laptop will not communicate with the TC ECU. The digi controller works fine with it, Mike at Racelogic sent me a Hyperterminal script, which communicated from laptop to TC ECU just fine, but for some reason when I try with the software I get the Failed message. Hopefully Mike will get back to me in the next couple of days with some suggestions.
This system had better be as good as I remember it being as I'm currently sick of the sight of it!
#117
Posted 17 March 2008 - 07:43 PM
#118
Posted 17 March 2008 - 08:46 PM
the shielding wont be causing you problems yet, just make sure you do earth it though.
prob a dry joint or something, or maybe a poor conection at the pin end?
Almost certainly my crappy soldering in that case. I don't think it's at the pin end. As I've been trying to trouble shoot I've managed to get them all to work at some point, just not all at the same time.
When does the shielding problem occur then?
#119
Posted 17 March 2008 - 09:10 PM
#120
Posted 18 March 2008 - 09:55 AM
