Cheers Arno for the details.
S1 Exiges use separate throttlebodies, so I guess you mean the 52mm ali TB as used on the MGTF and the S2 111S Elise?
Oops! Nope, it's a 56mm TB OK, was fitted to a S1 Elise (not exige as I typeoed above) . Bloke is racing the Elise, defaulted back to the standard 52mm item to be rule compliant so I took it off his hands.
If you want to use this, make sure the head is port-matched to the manifold! The VVC manifold runners are much bigger than the plastic manifold and it will not match up well with the ports in a normal head. This gives a large 'step' between the intake and the head, killing your airflow.
Yup, have my dremel out and ready to port match the head.
Do you also have the (steel) shim that's used with the new MLS gasket?
Also measure the liner height from the block face. They MUST stand proud. If they are not (or even below the level) then the gasket WILL fail.
Got the shim and steel dowels too. Find it hard to believe Rover used plastic dowels!!!! Hopefully none of the cylinder liners have dropped.
270's (or 633's) are usually OK for a little more top end. 285H's are probaby too wild for a plenum setup and you'd need to rev the engine a lot more to get the extra 'oomph'.
Engine should already have hydraulic tappets. You can reuse them. When you go to 285's or wilder cams then you probably would need to go to solid ones.
In either case it would be a very good idea to get an Emerald ECU as well and get the car mapped by Dave Walker properly to use the cams and headwork.
Read Dave Andrew's very good K-series page for lots more background info on working on the K-series: http://members.aol.c...ews/kengine.htm
That is an excellent link you supplied me with
As the freelander is a permanent 4x4 drive I would like to gain maximum midrange torque. I have a Emerald ECU for my supercharger project, I noticed it came with a floppy disk with a bunch of 1.8K maps from Dave Walker and Co. Will drop Emerald a line and see if they can do a deal for cams plus ECU.
erm look at newman cams, a lot cheaper and better than piper.
I ran a 1.6 K on Newmand "copies" of the lotus supersport cams and it was a very nice engine to map and ran sweet as a nut with significantly more grunt.
Can you remember the cam profile slindborg?
