Tyre Dot Codes, What Does It Mean?
8 replies to this topic
#1 Nic
Nic
  • 55 posts
Posted 03 February 2008 - 11:33 AM
I am sure I have read some thing about this before but can not find it on the search, what is the differnce between the tyres they but on the vx and the same tyres and model but say for a subaru, and has anybody put good year eagle F1's on the rear, with the standard front tyres, what is the result??
#2 Silent1
Silent1
  • 230 posts
Posted 03 February 2008 - 01:38 PM
The dot codes refer to the compound of the tyre.
As for mixing tyres, there's nothing worse you can do, with the result being a crash due to different handling characteristics front and rear.
#3 Nic
Nic
  • 55 posts
Posted 03 February 2008 - 02:39 PM
Won't be doing that then! I take it the vx has a softer compound, than the normal tyres, will it effect the handling a great amount?
#4 VIX
VIX
  • 9,497 posts
Posted 03 February 2008 - 03:47 PM
I could be wrong but I thought the compound (or possibly the sidewalls) for the VX were harder than the Audi and Lotus versions and yes it will affect the handling. Worth a search as it has been covered before. chinky chinky
#5 Silent1
Silent1
  • 230 posts
Posted 03 February 2008 - 05:18 PM
It'll affect the handling more than the money you'll save from buying them.
Speak to Dave Blackley @ Elite Garages on 01403 269694, tell him Oli sent you, he knows about the dot codes and i've not found anyone cheaper for tyres.
#6 Pooh Bear
Pooh Bear
  • 986 posts
  • Interests:Honey
Posted 03 February 2008 - 06:11 PM
I thought the dot code was the date of manufacture - week & year........
#7 VXJON
VXJON
  • 2,595 posts
Posted 03 February 2008 - 06:27 PM
A Quick Search Later which turns up the Great Dot Code debate 2006 chinky chinky
I just got a written reply from Bridgestone that the DOT code is not relevant:
Thank you for your enquiry.
As you have correctly assumed the dot code reference is not relevant
when purchasing the tyres. In case you have any problems though, I can
confirm that our product code for the correct tyre is IPC 77434.
Kind regards
Toni Tate
Contact Centre
Bridgestone UK Ltd
Telephone: 01926 488621
Facsimile: 01926 310810
I've used both the Loti and Vx specific dot code bridges and been unable to tell the difference, the both wear at the same rate, they feel exactly the same on road and they feel exactly the same after a hard trackday :rolleyes:
#8 VIX
VIX
  • 9,497 posts
Posted 03 February 2008 - 06:42 PM
Have a look at this thread:
http://www.vx220.org...s...c=49945&hl=
chinky chinky
#9 VXJON
VXJON
  • 2,595 posts
Posted 03 February 2008 - 06:58 PM
chinky chinky
Yep had a look at it :rolleyes: His tyre pressure was 30 psi no wonder the front felt "light" nothing to do with the Dot code.
That said the price of the specific bridgestone for the vx are normally cheaper than the elise ones thumbsup
