Track Day Tyre Pressures
#41
Posted 18 August 2008 - 10:06 AM
#42
Posted 18 August 2008 - 10:09 AM
#43
Posted 18 August 2008 - 07:51 PM
Dynamo, on Mar 6 2008, 21:45 , said:
What an interesting read...good post guys.
I was at Rockingham that day too. Good to meet you Max, Foxy and Partridge. Thanks Partridge for pointing me in the direction of Alan from Toyo; it was a step forward in the setup of my car.
I'm running 888s and found my turbo handled better on higher tyre pressures....I tried 24/26 psi (hot) followed by 29/31 psi (hot) and found the latter worked better at Rockingham at least.
According to Alan the optimum temperature for R888s is between 80-85 degrees C.....interestingly most peoples tyres didn't get anywhere near that....they were on more like 35-50 when measured on coming in to the pits. (although hard to know how much a tyre would cool down when coming in to the pits and it was a cold day)...so for trackday usage it seems the tyres have more to give, and would not start overheating (losing performance) except on all but the hottest days/longest sessions/hardest driving.
Guy182 (and anyone else interested): According to Alan @ Toyo, the arrow markers on 888s are apparently there to indicate where the minimum tread depth indicators are (the indicators are in the tread next to each arrow). They are to help determine if the tyre is road legal, not where you should be wearing the tyre down to laterally.
Oh and Max, your car is v quick!
..... now the question is what can I do to my Turbo to make it that quick?.... apart from a driver transplant
Hey Dynamo,
What tyre size do you have on 888? Do you use original wheels?
Lars in Sweden
#44
Posted 13 September 2008 - 03:36 PM
Edited by Dynamo, 13 September 2008 - 03:36 PM.
#45
Posted 13 September 2008 - 05:21 PM
I thought they might be a good tyre for the winter months; it sounds like they would be more sure footed in wet conditions.
Does anyone know if they will ever be released?
#46
Posted 14 September 2008 - 08:11 AM
Dynamo, on Sep 13 2008, 18:21 , said:
I was interested in the R1R tyres that Alan Meaker from Toyo mentioned were coming out this year. However, a quick web search has revealed this: link
If it keeps the characteristics of the R888 - in terms of sidewall strength - then I'll defo be ordering a set for winter trackdays.
Looks like an excellent tyre ;o)
#47
Posted 17 December 2009 - 08:46 AM
Here:
http://www.pistonhea...a...61&nmt=R888 set up advice from Toyo UK
#48
Posted 29 May 2010 - 01:22 PM
#49
Posted 29 May 2010 - 04:09 PM
#50
Posted 21 September 2011 - 08:21 PM
#51
Posted 22 September 2011 - 07:30 AM
'Sutol', on 29 May 2010 - 4:09 PM, said:
excellent thread, cheers Max for kicking it off. I'll print off Alan's post for future reference. I was told (by some experienced trackers) that once the tyres were hot to reduce the pressures down to what they would have been cold. I then found that the car didn't handle as well afterwards
(and thus thinking it must be my crap driving, which of course it still could be
My advice has always been to equalise them across the axle. As you point out going softer and softer just makes everything more sloppy , hence why I suggest as you progress through the day increase pressure as you get faster, to keep the sidewall stiff. I think it is the low starting pressures that overheat the sidewall causing uneven tyre wear and you get the feeling during a longer session that the tyre is going off. For any new tyre I'm testing road or track I always start at 27psi all round. Nothing worse than soft sidewall tyre on the front that you put less pressure chasing grip as it just become a horrid sloppy mess (Toyo T1-R).
As a short term fix , maybe for autocorsa or hill climb I understand why you might start low as its only a 1 minute lap as you won't encounter heat issues.
In other words, if you notice the tyre blueing on the sidewall junction to the tread, then you've got problems with your setup. I aim to keep them below 32psi as the upper limit.
#52
Posted 03 June 2013 - 06:03 PM
#53
Posted 03 June 2013 - 06:12 PM
26/28 for me hot on AD08
25/27 A048
That's some good dredging. Good to know I'm not miles off what someone who knows what he is doing does...lol
Edited by JohnTurbo, 03 June 2013 - 06:13 PM.
#54
Posted 07 July 2013 - 02:45 PM
Im running 16 inch TD 1,2's at the front and 17 inch 1.2's rear all on toyo R888's,
at donington yesterday i started off with Rear 26 cold and fronts 24 cold after about 10 laps I came in to the pits checked the pressures and checked the hot pressure came out 32 rear and 28 fronts, I decided to drop 4 psi out of each and have a few laps, what a mess the rear felt sloppy and the front felt as though it was rolling on to the tyre wall.
I increased the pressure to 30 rear and 28 fronts and all was back to normal
#55
Posted 07 July 2013 - 02:51 PM
Edited by jameso, 07 July 2013 - 02:52 PM.
#56
Posted 07 May 2018 - 04:19 PM
