Exige Body On Top Of Vxt
#61
Posted 08 February 2009 - 03:18 PM
#62
Posted 08 February 2009 - 03:22 PM
#63
Posted 08 February 2009 - 03:30 PM
That's exactly right.is that a front caliper conversion on the rear
a spacer bracket welded to a cut down hub upright ?
Front calipers on the rear, AP 4-pot on the front and adjustable proportional valve close to the (hydraulic) handbrake
ABS has been removed completely .
#64
Posted 08 February 2009 - 03:36 PM
Front calipers on the rear, AP 4-pot on the front and adjustable proportional valve close to the (hydraulic) handbrake![]()
i thought the abs wheel sensors were going to also drive the traction control , I wanted to do the same to drive a data logger.
its an amazing ongoing project
Edited by siztenboots, 08 February 2009 - 03:37 PM.
#65
Posted 08 February 2009 - 04:15 PM
ABS wheel sensor directly feed into the Racelogic TC, don't need the ABS circuit (box) for that. Perhaps a resistor network inside the ABS-electronics helps to improve signal strength comming from the wheel sensors, but I'm not sure on that.i thought the abs wheel sensors were going to also drive the traction control , I wanted to do the same to drive a data logger.
The tacho signal input is comming from there (some ABS-unit output) and I have not figured out how the ABS-sensor input is translated into speed pulse output (yet).
Not the best picture, but this is all that's left of the ABS. Electronics are only left there to feed the tacho signal.
After some initial problems (caused by a broken connector) TC works fine.
Proportional brake valve on the left
#66
Posted 08 February 2009 - 04:43 PM
#67
Posted 08 February 2009 - 06:38 PM
Yes. Theory that those are supposed to break before the subframe gets damagedStock toe links ??
#68
Posted 08 February 2009 - 06:51 PM
#69
Posted 09 February 2009 - 06:18 PM
Manus, are you bringing the beast ot Croix and Abbeville at the end of March? Will be really good to see it in the metal (or GRP, at least).
Yes, I'm planning to be there.
Some catching up to do
March 1st Zandvoort (1/4 mile sprint race, for the fun of it)
March 4 Zandvoort
March 14 Malmedy
March 27 Croix-en-Ternois
March 28 Abbeville
April 17 Donington Park
May 27 Brands Hatch (evening)
June 15 Spa-Francorchamps
June 16 Spa-Francorchamps
July 27 Silverstone GP (evening)
August 10 Le Mans
August 12 Val de Viennne
August 21 Ecuyers - Reims
August 23 Folembray
October 1 Spa-Francorchamps
#70
Posted 09 February 2009 - 09:28 PM
#71
Posted 10 February 2009 - 01:04 AM
I believe there's no GRP on this car anymore, except the windscreen frame.... the rest is all Carbon Fiber.
Manus, make sure to have it ready for Croix....
(the pax seat was promised over a year ago
Cheers buddy, all the best with the project.
#72
Posted 13 March 2009 - 07:05 PM
It has been finished for almost a month now, big thanks to Plans Motorsport
The car is road-legal in the Netherlands, passed its APK (MOT).
Some minor things to do, fire extinguisher upgrade, small adjustments on the boost controller, Video VBOX programming and other bits and pieces.
I will post a full story of he project soon
#73
Posted 13 March 2009 - 08:48 PM
#74
Posted 14 March 2009 - 07:51 AM
The project is finished!
Nice one
#75
Posted 14 March 2009 - 08:56 AM
Don't worry, you'll always find more to do!The project is finished!
Looks great. See you at Croix/Abbeville.
#76
Posted 14 March 2009 - 09:19 AM
#77
Posted 14 March 2009 - 07:47 PM
#78
Posted 14 March 2009 - 07:50 PM
#79
Posted 16 March 2009 - 08:02 PM
The car has gained a couple of pounds, about 890kg with half a tank of fuel and perfectly weight-balanced. Engine remained at 405bhp although mapping is more lean, Lambda closer to 1.0, slightly more turbolag. It runs on 30% Methanol in the water injection system which gives better engine cooling but I can´t tell, given cold March road conditions, whether it effects performance much.Nice one Hermann
like the new paint scheme and what's the bhp/torque now? have you added methanol into the water injection yet?
Cheers
Ian
Good news that the carbon doors arrived at Schiphol today, which will help with Lexan side windows for another 15-20kg's
It drives great, marginal understeer in fast corners. Looking forward to get some higher temperatures in the tires.niiice - so hows it drive?
Think you should remove the "exige" sticker
If I can find a Vauxhall/Opel sticker/badge which fits, I think I´ll put it on. Also no problem with keeping it as it is now, this car is more Lotus then the Exige or Elise, as the Z20LET engine was (partly?) developed by Lotus and the Rover or Toyota engines were not
Edited by manus, 16 March 2009 - 08:23 PM.
#80
Posted 16 March 2009 - 08:26 PM
