Exige Body On Top Of Vxt
114 replies to this topic
#101 VXT Tim
VXT Tim
    No it's not a Lamborghini!
  • 11,421 posts
Posted 19 March 2011 - 06:03 PM
What an absolute beast.
#102 The Batman
Posted 19 March 2011 - 06:28 PM
That fan in y our roof scoop, I take it that is speeding up the flow into the engine bay? Interesting and awesome car Imnotworthy
#103 VXT Tim
VXT Tim
  • 11,421 posts
Posted 19 March 2011 - 06:35 PM
Is there any in car footage knocking around?
#104 manus
manus
  • 363 posts
Posted 19 March 2011 - 09:07 PM
The heat of the engine builds up when driving slow or stopping. You could even smell the paint melting above the exhaust manifold... The fan solved that problem.
#105 manus
manus
  • 363 posts
Posted 19 March 2011 - 09:22 PM
330hp:
http://www.youtube.com/watch?v=2byK0oxMeOo
360hp:
http://www.youtube.com/watch?v=jGZzkdYrFsY
391hp: www.youtube.com/watch?v=s5r5TDPE2io
(Smoke is some cooling fluid left in the intake)
#106 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 19 March 2011 - 09:50 PM
look very good chinky chinky
#107 VXT Tim
VXT Tim
  • 11,421 posts
Posted 19 March 2011 - 09:53 PM
I take it that is engine bay temps bottom left, I was surprised how quick the temps shot up in the slow corners.
#108 moneyhunster
moneyhunster
    Oooh whats this bit do??
  • 1,168 posts
Posted 20 March 2011 - 07:31 PM
I love the woosh from the dump valve, looks rapid in the vid Imnotworthy
Edited by moneyhunster, 20 March 2011 - 07:31 PM.
#109 manus
manus
  • 363 posts
Posted 08 April 2011 - 08:07 AM
So many changing plans, time to make a fresh list of work in progress: Power target: 525pk at 8500rpm, weight target: 855kg and overall target: keep it street-legal Engine: • Borg Warner EFR7064 twin scroll turbo • Twin scroll exhaust manifold (heat wrapped) • 850ccm injectors • Steel crankshaft (-4kg rotational mass) • Stronger crankshaft-bottom support, strengthening ladder (+4kg) • Bigger valves, bronze fittings, dual valve-springs • More aggressive camshafts • Replace hydraulic valve lifters with solid lifters • Dry sump system for sustained oil pressure at high revs • Rev limiter to 8500 (for now, engine will hold up to 9000) • Engine support aluminium (top right-side) • Engine mounts (fill-up with Sikaflex) • Charge cooler upgrade (enforcement to 2.5bar) and upgrade connection pipes diameter • Remove oil cooler (oil tank and pipes will cool the oil) • Remove electrical water pump (need to keep that in mind before switching the engine off) • Lightweight 70-90A Alternator (2.58kg) and bracket • Titanium exhaust (with exception of cat). Maybe make it like: http://www.hjs-motor...ldaempfer.html • New air filter housing and fresh air intake (adjust sizes to turbo intake diameter) • Remove Apexi boost controller (ECU will handle it) • Heat shield removed Electrical: • 2nd fan connected to fog light switch • Front and rear clams with a single-plug (12/24 pin AMP) wiring disconnect • Remove Xenon • MIM01 Video-Vbox, new inputs to include in logging: o Traction control indicator( to visualize engine cut-offs/wheel-spin, pin 4 on the B connector – it sits at 5v but goes to GND when cuts are made.) o Throttle pedal position o Turbo RPM o Oil temperature (instead of engine bay temp) • Change battery cut-off switch, new location next to fire extinguisher • Battery behind co-driver seat • Clean up wiring • Build filter in ABS signal to traction control as spikes are causing the system not to work under 20MPH: http://www.lotus116....peedster052.htm (with many thanks!) Other: • Dry sump oil tank in front (battery location) • Roof vent system • New tow-hook • Interior heating system removed • License plate on alu strips • Fire extinguisher Zero 360 (Novec) Remote Electric 2.25kg Remote Pressure Discharge LL104-225-003 Cylinder Size (mm) 219L x 108 Ø Weight 3.09kg • Lower driver seat (1-2cm) and mount both chairs with L-shaped alu strip • Cruise control (reactivate it) • Block dirty air around radiator (foam) • Strengthen splitter and headlamp housing • Some painting: Front splitter in mat-black, doors bottom half silver like the rest of the car. Weight start 903 KG's Weight target 855 Alternator -3 Crankshaft -4 Flywheel -0,5 Strengthen engine 4 Oil cooler -4 Oil tank 12 Dry Sump pump 8 Wiring -8 Fire extinghuisher -2 Chair supports alu -5 Exhaust Titanium -20 Heating system out -9 Electrical water pump out -1 Apexi boost controller -1 Borg Warner 7064 2,5 Exhaust manifold 1,5 Remove Xenon -2 Alu engine support bracket -0,8 Stengthen splitter 1 Strenghten headlights 0,3 New tow-hook 0,5 Charge cooler buffer tank -4,5 Air filter housing 0,5 Tophat -0,242 Intake manifold -2,3 Uprights Nitron -4,8 Steering wheel carbon -1 Lexan side windows -6 Toe link upgrade 1,2
Edited by manus, 08 April 2011 - 08:13 AM.
#110 techieboy
Posted 08 April 2011 - 08:54 AM
Ouch, that's going to cost a bit. :o
Aren't you and the car based in Belgium? Given how many problems another member had with the Belgian MOT and proving drilled brake discs and the blue anti-roll bar where original equipment, will keeping it street legal even be possible.
Good luck. thumbsup
#111 2GOOD
2GOOD
    Old Timer zzz...
  • 4,451 posts
Posted 08 April 2011 - 09:29 AM
Dutch No. plate thumbsup
#112 techieboy
Posted 08 April 2011 - 09:35 AM
Ah good, obviously a little more relaxed than the Belgian authorities. thumbsup
#113 smiley
Posted 08 April 2011 - 09:57 AM
In belgium, there are extreme regulations around tuning. Here's the offical goverment website, on what's allowed, and what not (no english) http://www.how2tune.be In holland, if the car meets MOT regulation, it's fine.
#114 ChrisS1
ChrisS1
    Club OEM
  • 8,360 posts
Posted 08 April 2011 - 10:07 AM
Wow amazing car!
#115 manus
manus
  • 363 posts
Posted 08 April 2011 - 01:12 PM
Dutch MOT (APK) has only some basic safety checks and a simple check on the engine exhaust-gasses.
Few things I need to do before the annual check:
- Make sure the original full-size front license plate is there when they need it
- Make sure that the garage knowns which rmps are best for legal emmission levels (ECU program holds small RMP range which is surprisingly environmental frienldy :mellow: )
- Make sure the color of the car is mostly black (listed in the paperwork)
- Protect the knife-sharp splitter with some protection material :glare:
Things I do not have to worry about :rolleyes: include:
- Hydraulic handbrake, big brakes, no ABS
- Changes on bodyworks, suspension, wishbones, wheelbase :blink:
- Engine modifications :unsure:
- And all the rest....
Edited by manus, 08 April 2011 - 01:14 PM.
