Tyres 195/45r17
36 replies to this topic
#1 Nillet
Nillet
  • 1,728 posts
  • Interests:Whisky, Formula 1
Posted 24 March 2008 - 01:56 PM
Did the search and couldn't find if you britts discovered this...
Thanks to the new Suzuki Swift there are new dimensions on the market.
The Germans have got an OK from Yokohama to put it on the original Speedster front rim.
--->German forum thread<---
Perhaps not for trackmaniacs but might be a cheap option for the understeering rest...
Searched mytyres.co.uk and found Goodyear and Yokohama in this dimension.
Sorry if if this is a repost...
#2 vocky
Posted 24 March 2008 - 02:35 PM
the tyre links
195/45/17
235/40/17
so what are they like when used on a vx220 / speedster ?
my tyres
Edited by vocky, 24 March 2008 - 02:43 PM.
#3 Initial D
Initial D
  • 386 posts
Posted 24 March 2008 - 02:37 PM
Any chance u could translate that :yeahthat: over here :rolleyes: Will Goodyear 195/45r17 really fit the original front rims. Bargain for £68 Imnotworthy
#4 Nillet
Nillet
  • 1,728 posts
Posted 24 March 2008 - 02:50 PM
Hello, the topic went already last week around. Thus there is a new tire of Yokohama (S.drive) in the size of 195/45 R17 85W and 235/40 R17 91Y. When the tire exactly on the German market does not come knew Yokohama exactly yet. Explanation of Yokohama that the tire on the Speedster rims fits has I already. Yokohama.PDF
With reifen.com gibt's the tires already. 195/45R17 235/40R17 I believe that it ne good Alternatieve to the 205 is...
Dont know why they opt for 235 rear, hello understeer...
Translation by babelfish.altavista.com.
#5 Nillet
Nillet
  • 1,728 posts
Posted 24 March 2008 - 02:58 PM
Seems like they have trouble with TÃœV (carinspection).
They only have OK from Yokohama and not from Goodyear.
I use R888 so this is not for me.
Think this is the yokos:
#6 rabidh
rabidh
  • 1,640 posts
Posted 25 March 2008 - 11:33 AM
That looks like great news! I might do that for my next set... I'm currently running 205s on rear rims on the front - but the way the tyre is stretched to fit it does worry me a little. I'd much prefer a wider tyre on a thinner rim.
#7 oakmere
oakmere
  • 2,143 posts
Posted 25 March 2008 - 02:47 PM
I will be needing new tyres next month so this is a possibility but there is no financial advantage. Anyone got any experience with these tyres as the last thing I would want to do is upset the handling. I have not had a problem with understeer but don't like the look of the skinny 175 fronts. Cheers Oakmere
#8 alanoo
alanoo
  • 1,324 posts
Posted 25 March 2008 - 03:24 PM
http://www.myspeedst...pic.php?t=12850
Same in France with the Goodyears
#9 vocky
Posted 25 March 2008 - 04:52 PM
what does the vx handle like with them fitted :unsure: what tyre pressures are best :unsure:
#10 Anarchy
Anarchy
  • 2,237 posts
Posted 25 March 2008 - 08:14 PM
I dont know much about tyres but this got me looking on a tyre website at various tyres. Are there certain rules regarding what tyres will fit without the risc of them popping off? I read a lot about 16" fronts, so would a wider lower profile tyre be a step closer to this but keeping the same wheel? eg. NS-2 185/35 R17 82V TW (only£50) So is 185 the width and 35 the profile, 10mm wider and 20mm smaller diameter? Like I said I know nothing about tyres :rolleyes:
#11 Nillet
Nillet
  • 1,728 posts
Posted 25 March 2008 - 10:17 PM
Optimal width of the rim for standard tyres is: 40 milimeters less than the tyrewidth (and divided with 25 if you whant inches). Example 175 tyre wants 5,4 inch rim (175-40)/25=5,4.
If you have racetyres/semislicks (don't know your word for it, we call it R-tyres) you should add 1,5-2 inches to the above. The 175 then wants 6,9-7,4 inch rim.
Not optimal but it works for me:
On 7 inch rims I have 205 front and 235 rear...
Read more on wheels and tyres here:
http://www.victoriat.../wheeltech.html
http://www.victoriat...m/tiretech.html
#12 njc11
njc11
  • 1,057 posts
Posted 26 March 2008 - 02:24 PM
Found this..
>Tyre Calc<
175x55x17 - 24.58inches (624mm)
195x40x17 - 23.14inches (588mm)
195x45x17 - 23.91inches (607mm)
Just need abit more feed back from people who have these.. the fit looks ok on the rims..
Fronts & rears (Yoko Sdrives) similar in cost to O.E Bridgestones.. But if you go for Goodyear Eagle F1's then you could save abit of money..
Nick
chinky chinky
#13 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 24 April 2008 - 06:23 PM
Has anybody tried the 195/45/17 yet? Im keen to find out if this works.
#14 Initial D
Initial D
  • 386 posts
Posted 24 April 2008 - 06:33 PM
:yeahthat: Need new tyres soon, anyone?? :tumble:
#15 don.hasi
don.hasi
  • 320 posts
Posted 24 April 2008 - 07:46 PM
Hello everybody
at the moment we have not much direct comparisons to the stock ones. One has changed to them and is for the first few days very pleased. But there aren´t any longtime experiences on track/hill/alps/... We will report as soon as we got further details. Me for myself will change a set too B) but for first results it will take 4weeks...
Kind regards
#16 JawZ
JawZ
  • 2,571 posts
Posted 24 April 2008 - 07:58 PM
Had a good report from a Swedish member who changed to these as well thumbsup
#17 southpaw
southpaw
    sans vx for now
  • 2,462 posts
Posted 24 April 2008 - 09:06 PM
thanks for the update chinky chinky I don't need tyres yet but could be tempted.....
#18 timmyp
timmyp
  • 551 posts
  • Interests:Rugby, Golf, Anything with an engine.
Posted 26 April 2008 - 08:50 PM
Noticed on blackcircles that the goodyear eagle F1 is also now available in 195/45 R17, for around £75 fitted or something. Could be worth a look
#19 RCduck7
RCduck7
  • 125 posts
  • Interests:sportscars, home cinema, videogames... and sportscars like the VX220.
Posted 27 April 2008 - 07:47 PM
I'm not sure but 2 sizes bigger on the original front rim wouldn't that make the tyre a bit swelled up??
If yes, it's a bit pointless as to have full contact path with the tyre on the road the tyre surface needs to be flat.
If the rim is not big enough a 185/R17 might be a better option??
I'm just guessing...
Is there a 185/17 tyre available??
Some good pictures in close up of an 195/17 tyre on the vx220 original front rim could reveal more.
#20 simsy
simsy
  • 957 posts
    DOB is not real...
Posted 28 April 2008 - 06:52 PM
I put 195- 45 / 17 pirelli drago 5000 in my vx na, ( max width allowed on standard front rims) fit perfect, look great, car drives great... had s1 111s before, never driven a vx other than this set up 225's pirelli 6000 on rear... will not change this set up
