I think you are missing one key element, you have to do with the M62 efficiency curve
If you want to hit 300+ BHP with low compression (let's say 9:1), you will have to get more boost as you said, so a smaller pulley and you will certainly land in an efficiency zone of the M62 were it is so unefficient you'll never be able to cool the intake air enough.
I am currently spec'ing my next engine after the NA one (autumn 2009 release), it will be a supercharged LE5/LSJ hybrid with a 380BHP target.
CR will be 10.5:1 but not Wiseco
(or specially made ones for boost)
EDIT : oh and another thing specially for you Steve.
Having 8.9 pistons does not mean at all you effectively have 8.9 CR, especially in an hybrid.
LSJ/Saab cylinder head gasket are thinner than 2.2 ones. I am not sure the valves have the same big dish on the 2.0 head too
Hi alanoo,
I agree. Heat saturation is the BIG problem. The 2 pass end-plate helped some but the TVS should now remedy this. I still haven't figure what gasket configuration I'm going to finally run with. The smaller valve areas used in the SAAB turbo head are OK for the SC configuration, a narrower stem on the valve is an option that can be considered though....
Have you figured what piston ring configuration you going to use on a 10:5:1 CR? I've heard of ring failure and oil seepage been an issue on FI running those higher CR's.
Steve
Edited by speedster, 31 March 2008 - 10:49 PM.
