Liners are off, took less than 30 mins - I've got a far few pairs of hands to help lift it all off tomoz - I've just got to work out where i can store the clam for a few days
Are there any bolts that are more stubborn than the others? - The two that hold the rad/prop the bonnet look a tad rusty, but everyting else is like new.
Oh yes.... I had 2 of the little bar stewards... The one by the ABS unit is a sod, and the only way to get it off, along with the other 2 across the back, is to remove all the others bar those 3 along the back then grind them off from where the rad was as per Steve's instructions, but unlike me, read the whole document first so that you lift the housing and slide the rad out with those 3 screws still attached... then grind them off.
Bolt # 2 that proved somewhat troublesome was the lower one on the inside of the pax door going into the sill. I purchased a 90 deg head for the dremel and HD cutting blades and gut it off. It was spinning in the nut that was glued on the inside of the sill. Then removed black sill protector and pulled what was left of the glue and nut/bolt off from inside the sill and replaced the nut which I fixed in pace with a little araldite. Fortunately I had replaced my black sills recently and had not glued them down. They were not glued when I put them back so I always have easy access.
Edited by ukgulf, 16 July 2008 - 09:14 PM.
