I thought RS14's were primarily an endurance pad. High Ceramic content which makes them munch discs.
Yes, they do chew through discs... seems to go through a set of discs with a set of pads. No worries though - discs are cheap.
As others have said, I've had no problems with them from cold.
Yep, no problems from cold.
Set of discs per set of pads? Are you getting your discs off a pikey from ebay machining them out of a metallic substitute on a lathe that fell off the back of a lorry?![]()
Should be doing much better than that.
No, I get them direct from the Cadbury's factory
