Dash Not Working, Help!
Posted 13 May 2008 - 12:45 PM
Posted 13 May 2008 - 12:59 PM
Posted 13 May 2008 - 02:35 PM
sorted now..... phew...
..if it happens to anyone else in future try holding the reset button for 10seconds and turning the ignition on.
was that before or after you bashed the dash really hard a few times?
Posted 13 May 2008 - 03:02 PM
Posted 13 May 2008 - 03:18 PM
So the clock works ok now?
lol... Joking aside, is it possible to get a clock for a VX? Thats the only thing I miss since I got it. I dont wear a watch.
Posted 13 May 2008 - 03:30 PM
I just use my radio??? Do you not have a clock on yours?
If not you could try...
HTH
Posted 13 May 2008 - 03:33 PM
Posted 13 May 2008 - 03:34 PM
HTH
LOL.... fantastic idea.. i will pop into Argos and WHSmith this evening.
Posted 14 May 2008 - 02:01 PM
you knew what i meant
yes but all going well stll!
Posted 31 May 2008 - 11:27 AM
Posted 31 May 2008 - 11:34 AM
Posted 31 May 2008 - 11:57 AM
Posted 31 May 2008 - 12:01 PM
The first time it happened there was no condensation, however on the occurance there was?I've seen a few threads about condensation appearing on the clock face when left in the sun - does this happen to yours at all?
Failing that you could try removing the ECU fuse for 15 mins and see if that helps
Would removing the ECU fuse still help?
Posted 31 May 2008 - 12:03 PM
Posted 31 May 2008 - 12:22 PM
If there's water in the unit then I'd say that was the most likely cause
If you're still in warranty take it to the garage on a hot day and show them the condensation
Strange though, I have had the car since last sept and it hasnt shown any signs until now?
Do you think there is anyway i can seal it back up myself, thing is the condensation went away after about 10mins on the motorway with the roof off
Thing is the only way the dealer is going to show any interest in the problem is if the condensation is there or the dash isnt working - difficult if its not lasting long.
I can put up with it now and then but am just concerned if it will get worse/ cause permanent damage?
Do you think it may be worth undoing the screws around the indicator storks, removing the panel and checking the connections/ wiring?
Edited by JTRaider, 31 May 2008 - 12:24 PM.
Posted 31 May 2008 - 12:25 PM
Posted 31 May 2008 - 12:30 PM
If it's under warranty I wouldn't mess with it - you could always take photos when it happens
yeah i could do - I need to check if the problem is covered anyway. Its one of those warrenties you buy extra, only i managed to get a free one for one year! (it's not a vauxhall dealer either). I tried getting the expension tank changed on it a while back but they wouldn't have it grrrr!
Posted 31 May 2008 - 01:44 PM
Posted 31 May 2008 - 04:52 PM
Posted 31 May 2008 - 05:17 PM
When you open the Stack backplate, there is a small sachet with material which should prevent any moisture inside. You can take this out and dry the stuff in an oven on very low setting. (1-2h on 50-60*C should do it)
Maybe it helps.
Thanks, is that the plate that is below the clocks held on with 4 screws? As well as drying out the material as you suggested maybe a sachet or two or silica would help as well?
