Quality as always Winstar
Very interesting, as you say, to note how high up a wing would have to be to be in truly clean air
Subseamac - I've though similar re vortex generators, but had come to the conclusion (and I'm not sure I see anything in Rob's plots to convince me otherwise) that without a smoother rear profile (i.e. exige typre rear cover) they wouldn't really do anything. Very open to being told I'm wrong though.....
I did wonder if some sort of (chavtastic) roof spolier contraption on the back of the roll bar cover might help? Not sure I could ever bring myself to do it though
You can see on winstar's model that with the rear diffuser the flow of air is substantially nearer the boot lid and edge of the boot than without. One thing that's particularly interesting is the change in airflow above the engine lid showing that even though it gets better with the diffuser, it is still very weak and not sufficient to properly cool the engine. I wonder if a combination of VGs on the trailing edge of the roll bar cover associated with an effective diffuser may not - just - get us some proper air circulation above the engine. I've also been thinking about a more discreet very small/thin wing type deflector that could be positioned on the trailing edge of the roll bar on the turbo side to divert some flow down over the engine bay. With a diffuser, the low pressure created above the boot will then help circulate that air.
p.s given the scale on winstar's model I would say that diffuser needs to stick out a good 20cm!!! Winstar could you confirm as anything more than 5cm isn't exactly practical and would end up being used by pedestrians and small animals as an alternative means of transport (..)
Edited by subseamac, 20 May 2008 - 07:41 AM.
