so a 7-12 degree diffuser clearing the rear by 5cm will work just fine. If anything, having it sat 2cm below the clam at the rear (like Max) to clear the exhaust "hump" will improve cooling and reduce the angle.
I like your idea of a small extension to the roof slope maybe with a couple of VG's attached to it. Should be easy to get a 10cm wide piece of transparent perspex to extend the roof and fix on either side, stick on the VG's, attach a few small ribbons to the engine cover etc and check improvements in flow at different speeds (right now water droplest don't even move off the engine cover/ rear spoiler)
if your going to drop the angle like MAXR then Ideally you should/can get rid of the small center channel and alter the number of vanes to change the diffusion, there's also some good ideas for other things like extensions under the wishbones stopping flow creating lift on the Revire Exige wind tunnel tests. Edit click pdf
Repalceing the rollover hoop cover with somthing more aerodynamic could also be an oportunity to save some weight you wouldn't belive how heavy it is.
Edited by Winstar, 20 May 2008 - 09:05 AM.
