Rear Tow Hook
6 replies to this topic
#1 OGR
OGR
  • 104 posts
Posted 21 May 2008 - 03:53 PM
Hi,
anybody know if this will fit to a Speedster Turbo ?
http://www.sector111...unction=product
Cheers Oliver
#2 Mr_M
Mr_M
  • 946 posts
Posted 21 May 2008 - 04:17 PM
Hi,
Cheers Oliver
any particular reason for not using these - Clicky - instead?
or if getting past a diffuser is an issue, how about these - Clicky - ?
#3 subseamac
subseamac
  • 584 posts
Posted 21 May 2008 - 06:19 PM
The sector111 you want is rather this one as the one you mention will interfere with the exhaust hump.
http://www.sector111...ng_tow_hook.cfm
they're expensive and by the time you pay post and customs you're looking at a £200+ tow hook ...
Also as mentioned, neither will work too well with a diffuser, they also seem to have a tendency to vibrate against the undertray etc etc. I would go with the ones mentioned above and stick one on each 8mm bolt. If you are convinced you're prone to plunging into knee-deep gravel that would make access to those locations difficult you could always make a simple steel wire loop through the two tow hooks and only duck tape the apparent end loop on when you're on track? (I just thought of this - genius!)
#4 OGR
OGR
  • 104 posts
Posted 21 May 2008 - 09:42 PM
Thanks guys haven't thought of the diffusor problem. Ordered the Elise-Shop ones and by the way great idea with the steel wire loop subseamac thumbsup
#5 OGR
OGR
  • 104 posts
Posted 26 May 2008 - 08:32 PM
Sorry need help. Where exactly are these hooks fitted to ? A picture with them fitted would help. I see two alternatives either next / close to the undertray air ducs so basically in front of the wheels / close to the chassis looking in driving direction or the two bolts rather in the middle of the rear diffusor so closer to the backend of the car. Thx Oliver
#6 techieboy
Posted 26 May 2008 - 10:25 PM
The rear towing eyes are attach through the rear diffuser into the chassis, using the one of the two larger M8 fixing points, just behind the join between the middle undertray and the rear diffuser.
In this picture, the yellow circle highlights the correct bolt (you can't see the other one from this angle). I haven't got the tow eyes fitted in this picture but I'll take another picture tomorrow, if this is no good?
#7 OGR
OGR
  • 104 posts
Posted 27 May 2008 - 06:19 AM
Thanks Techieboy now it's clear Cheers Oliver
