Speedlines - Possibilty Of Getting Them?
#41
Posted 03 June 2008 - 07:21 PM
#42
Posted 03 June 2008 - 07:51 PM
5 isn't the minimum order, it's the maximum - I could have just got a single set for little old me
. I still have to wait for them to confirm they have the correct tooling, but it did sound promising earlier!
I know it's the maximum - I thought I would be the last one?
Or was I too late
#43
Posted 03 June 2008 - 08:01 PM
List of those interested:
JasVXT
Ratboiler
Matt
Namaah
ChrisUK
Crazy
*However* providing they confirm the rears can be made, there is also another option, using a 7.5" wide 16" dia front which would be by the same manufacturer as the rears (hence colour match will be identical etc...)
Effectively, infinite sets of these would be available (and provide some level of future proofing!)
The only downside is that sticky tyres (R888s / A048s) will not fit, as they only make a 55 profile in 205 width, and 205s would be required as the minimum tyre size. The normal road tyres ie T1Rs, Kumhos etc will be available tho
#44
Posted 03 June 2008 - 08:05 PM
Bagsy first dibs on your MO's if you get yourself this new set!
#45
Posted 03 June 2008 - 08:12 PM
Sorry mate, they've already been spoken for if this comes offBagsy first dibs on your MO's if you get yourself this new set!
BTW, the guy is also coming back to me with a min. quantity order for them to produce tooling for a 7"x16" front, so keep watching this space
#46
Posted 03 June 2008 - 08:31 PM
No no, you were not too late
JasVXT
Ratboiler
Matt
Namaah
ChrisUK
Crazy
That's excellent. Keep me posted
I definately want a set ... I'm in need of some new tyres soon so this is perfect timing. Plus - Some new wheels in black would help my little beast on her way to infinate sexiness
#47
Posted 03 June 2008 - 08:35 PM
Oooooh YesSome new wheels in black would help my little beast on her way to infinate sexiness
#48
Posted 03 June 2008 - 09:00 PM
Oh well, worth an ask!
#49
Posted 04 June 2008 - 09:10 PM
#50
Posted 04 June 2008 - 09:24 PM
#51
Posted 04 June 2008 - 09:28 PM
#52
Posted 04 June 2008 - 09:33 PM
He still hasn't got back to me to say whether he can sort the tooling
Well keep me posted should have mine back on the road soon just finishing off fitting charge cooler. Then need to get down to courtenays again for the stage 4 this time
A set of speedlinealikes would finish it off nice
#53
Posted 04 June 2008 - 09:44 PM
Good things come to those who wait ... patience ...
gimme gimme gimme
#54
Posted 10 June 2008 - 08:37 PM
Spoke to them again today, they have said they should be able to make the wheels (will have to physically locate the cast, but has been told it's there), but they will need to refurbish the old casting and 'develop' new tooling in order to make a 7" x 16" front in that design. She did point out that this is an old design of wheel, and as such will be very heavy in comparison to modern alloys (
NOT-SO-GOOD PART:
However, due to the need to refurbish the old cast and tooling, they will require a minimum order of 60 of each wheel (to be expected I guess), hence all change, and there is now a minimum order of 30 sets of wheels
GOOD PART(S):
The rear will be 8" x 17" so 215 to 245 rears can be used (guessing 225 will be the common choice tho!)
The fronts will be 7" x 16" so will take the 195 tyres (ie same size as the Speedlines) and sticky tyres can be used
Obviously spares will be available if anything unfortunate were to happen at a future date
And the price:
Fronts - £117+VAT
Rears - £138+VAT
So a set will come in sub £600 including VAT
Postage is approx £15+VAT per set (UK)
And a bonus: - for no additional charge they can be finished in Black, Silver, White, Gold or Gunmetal
These are them:
Rears:
Fronts:
They would take 4-6 weeks to manufacture / paint / pack from date of order.
So... can we find 30 people that would want a set, or am I just getting my hopes up!
#55
Posted 10 June 2008 - 08:57 PM
#56
Posted 10 June 2008 - 09:01 PM
Forgot to add (anoth Good Point!)
She said that as they are machined from the cast blanks, they will see if they can lighten them, as the existing design is effectively over-engineered
#57
Posted 10 June 2008 - 09:13 PM
#58
Posted 10 June 2008 - 09:16 PM
Yep - means there's no chance of getting two different shadea of blackAs previously stated count me in, probably the better solution than mixing manufacturers anyway.
Noticed from the above photo they have a 4 stud pattern, take it ours will be 5 ?
Are the offsets big enough for the front AP brake kit ? Obviously the Speedlines were.
Anybody want 2 sets
They will be the correct fitment (as per my MO6's that I'm running at the moment
I'll double check about the AP kit, but can't forsee any probs as there is about 10mm clearance on the Speedlines
#59
Posted 10 June 2008 - 09:29 PM
#60
Posted 10 June 2008 - 09:55 PM
