Sooo...
Following on from a number of other threads I have investigated the possibility of getting a set of wheels made up as per the VXR speedlines. Speedline have point blank refused to produce any more, however the guys in the Speedline distribution centre suggested I try Compomotive as they *cough*copied* both the 5 and 6 spoke designs from Speedline. (the guy in the Speedline centre used to work for Compomotive, so he should know I spose!)
I know a few guys from Compomotive (as I'm running their 6-spoke wheels at the moment) so made some inquiries:
They have said that they will be able to make up both the 16"x7" front and the 17"x8" rear; the fronts will have an offset of 20mm (as per the TMS TD1.2s etc..) and the rears an offset of 35mm (as per standard/Speedline). Tyre widths that can be run on these wheels are 195-225 on the front and 215-245 on the rear.
However, they do not have the casts as part of their normal production hence this will be a special run, and the casts will need re-conditioning, hence there is a minimum order quantity of 60 of each wheel (ie 30 sets in total) required to make this worth their while.
I went in and met the director, who gave me a tour around and showed me some of the wheels they had hidden away from yester-year out back (they tend to knock off a couple of extras as spares):
Fronts (very dusty!)
Rears
The 'dish' will not be as pronounced on the ET35 (a clearer picture will follow) as these rear wheels in these pictures have a very low offset
Both together
These are heavy wheels (as per the original VXR Speedlines) but they are going to use some clever machining to reduce the weight which should bring the rears out somewhere around 11 kilos (obv. the fronts will be less). They are going to model them to get an accurate weight, and also provide a picture of what the rear will look like with a slightly smaller 'dish'
They will be available in a choice of colours:
Black
Gold
Silver
Anthracite
White
Which can (kind of!) be seen here
And....
The price - they will be £618 all in for this group buy only - that includes VAT and shipping to UK - shipping to EU would be an additional £15
But we need 30 sets, failing that a dealer may have to take some, but then there will be quite a mark up after the group buy has finished...
