![Photo](http://www.vx220.org.uk/forums/uploads/profile/photo-thumb-3970.png?_r=1431376643)
Supercharger Self Fit Kit
Posted 06 July 2008 - 08:41 PM
Posted 07 July 2008 - 07:34 AM
![:blink:](http://www.vx220.org.uk/forums/public/style_emoticons/default/blink.png)
![:drink:](http://www.vx220.org.uk/forums/public/style_emoticons/default/062802drink_prv.gif)
![rallly](http://www.vx220.org.uk/forums/public/style_emoticons/default/rallygraemlin.gif)
Posted 07 July 2008 - 07:40 AM
Posted 07 July 2008 - 08:07 AM
You take me to supper, and I'll charge you. How's that?I have been looking at getting a supper charger
![;)](http://www.vx220.org.uk/forums/public/style_emoticons/default/wink.png)
Apologies
![:(](http://www.vx220.org.uk/forums/public/style_emoticons/default/sad.png)
Posted 07 July 2008 - 10:50 AM
Posted 07 July 2008 - 11:40 AM
Courtenay's seem to have a new generation Supercharger install, where they reckon they don't need another ECU or extra injectors. If they've sorted that then you may be able to buy a supercharger kit, sort the alternator, and then get them to remap the ECU for you...
Oh ! Never heard of that version...
Anyway, I guess you still have to manage the Alternator/idle pulley... And all the other little things....
![B)](http://www.vx220.org.uk/forums/public/style_emoticons/default/cool.png)
Posted 07 July 2008 - 11:51 AM
Yes heard of that version, I dont see the alternator or other bits as a problem as I have all the facilities to make what is needed. Looking at the GM kit you dont even need to fit a charge cooler unless you go for the higher boost presures. But could a charge cooler rad be fitted in the same place as the turbo intercooler is? This would make the plumbing easier?
Edited by Mike-F, 07 July 2008 - 11:51 AM.
Posted 07 July 2008 - 11:56 AM
Is this behind one of the wheel arch air intakes? If so, and IIRC, this is where Courtenay first had their charge cooler rad but have relocated it to the front of the car where there is room for a bigger a rad. Worth a search.But could a charge cooler rad be fitted in the same place as the turbo intercooler is? This would make the plumbing easier?
![thumbsup](http://www.vx220.org.uk/forums/public/style_emoticons/default/thumbsupgraemlin.gif)
Posted 07 July 2008 - 12:40 PM
This is my settings (no pic available though)... Done by Hitec in the first conversions... As VIX said, the rad is now in the front...
However I never had any temperature issue with the charge cooler in the right wheel arch (although I relocated it a little last year when I removed the rear clam).
Posted 07 July 2008 - 12:45 PM
Sounds like a plan then! I reckon I can get a supercharger and manifold for around £600 (secondhand) just got to hide the cost from the wife! It will be a nice job for the SORN period of winter.
Posted 07 July 2008 - 01:00 PM
Where do you reckon you'd be able to get them that cheap? For that price SC is a very attractive option - well worth fiddling with the alternator for
![:)](http://www.vx220.org.uk/forums/public/style_emoticons/default/smile.png)
Posted 07 July 2008 - 05:57 PM
![:closedeyes:](http://www.vx220.org.uk/forums/public/style_emoticons/default/closedeyes.gif)
Posted 07 July 2008 - 06:41 PM
Pic done... (with crappy mobile
![:blush:](http://www.vx220.org.uk/forums/public/style_emoticons/default/blush.png)
![Attached File](http://www.vx220.org.uk/forums/public/style_extra/mime_types/gif.gif)
(see some other pics here http://www.vx220.org...mp;#entry752060 )
Edited by Marco Polo, 07 July 2008 - 06:45 PM.
Posted 07 July 2008 - 08:26 PM
US ebay.... Just have to be a bit patient but they are ther...
I'm also looking into this, as I have a complete 2.0 SC'ed LSJ engine standing in my garage. But this has a pulley set-up for an AC pump so will need to make something different. (I have some pics of the Hitec/Courtenay idler set-up, but also from the US Ariel Atom with the 2.0 SC engine which I like more.)
But with the latest ECU cracking of Courtenay (reprogrammed ECU + standard compression) I will probably first equip my 2,2 with the SC to their current 250PS set-up...![]()
(I know Hitec delivers kits fir DIY, so have to ask what the costs are for some seperate items + ECU reflash)
Job list:
- make idler pulley set-up
- Install manifold + SC (+68mm TB ?)
- rewire sensors (if needed?)
- mount bigger injectors
- route cooling hoses through side sills
- install IC pump + IC radiator in front
- extra wiring
- reflash ECU by Courtenay/Hitec
+ Mount sport exhaust!!
Sounds like what I have in mind! with the exception of the charge cooler mounted as per Marco Polo's, I dont see that a front charge charge cooler rad is needed in the current summer climate! I not certain but I dont think they fit charge coolers to some GM SC kits used at lower boost presures (<=10psi)
Thanks for the pictures Marco
Posted 07 July 2008 - 08:33 PM
Job list:
- extra wiring
Forgot to ask, how much did it cost to get it shipped over?
thanks
Mike
Posted 07 July 2008 - 09:10 PM
Some more info : I have Turbo Air-intakes (copies) and the current positionning/fixing of the radiator has been redone by myself last year with the clam off. The original positionning/fixing done by Hitec was not so good (because done with the clam on !
![:sleep:](http://www.vx220.org.uk/forums/public/style_emoticons/default/sleep.png)
I think some more cooling could be achieved by joining the rad to the air-intake with plastic/alu sheets (driving all the air flow to the rad)
Posted 07 July 2008 - 09:19 PM
Some more info : I have Turbo Air-intakes (copies) and the current positionning/fixing of the radiator has been redone by myself last year with the clam off. The original positionning/fixing done by Hitec was not so good (because done with the clam on !)
I was hoping to keep the intakes as they are, but cowling in the rad would possibly counter the loss. do you have a temperature gauge on you charge cooler system? if you do does the temperature rise much ?
Posted 07 July 2008 - 09:52 PM
Yes, I have installed a water temp sensor/gauge (VDO)... But it is a 40-120° system... The needle hardly move in normal use, raise a little in traffic jam/track day... I have checked the reading with an infrared temperature gun...
![:wacko:](http://www.vx220.org.uk/forums/public/style_emoticons/default/wacko.png)
Posted 07 July 2008 - 10:01 PM
thanks
Mike
Complete engine only freight shipment by boat was about $300,- to Rotterdam port. (Had the engine dropped off at freight terminal by seller for a little extra.
I used these guys, perfect! https://iqglobal.com...from_main=1#top
Posted 07 July 2008 - 10:16 PM
thanks
Mike
Complete engine only freight shipment by boat was about $300,- to Rotterdam port. (Had the engine dropped off at freight terminal by seller for a little extra.)
Thanks I will take look
Also tagged with one or more of these keywords: supercharger, self fit kit, sc conversion
General Discussion →
Tuning & Modifications →
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
VX220 Discussion →
Supercharger ConversionStarted by Chrisp , 06 Dec 2015 ![]() |
Water Injection OptionsStarted by CHILL Gone DUTCH , 08 Nov 2015 ![]() |
VX220 Discussion →
Self Installation Supercharger KitStarted by Singingwolf , 07 Aug 2015 ![]() |
The Market Place →
Car Parts Wanted →
