This sounds great Jon
One little question, since I don`t live in UK, is it possible to ship the ECU to you and get the base map,
and buy injectors and map sensor from you. Then get a fine tune on the Dyno at a later occasion?
Yes we can do that, but you must have it checked for AFR etc on a Rolling Road lacally before you go mad with it, just to be safe![]()
Jon
Sounds perfect Jon, I have a permanently installed wideband lambda and access to a rolling road so that won`t be a problem, I will contact you direct when I start with my installation. Will keep the car up and running as it is during the summer....
By the way, which compression ratio are you running on this setup?
