![:rolleyes:](http://www.vx220.org.uk/forums/public/style_emoticons/default/rolleyes.gif)
I got the LSJ pulleys along with my supercharger, so I hope it will bolt straight on..
Like this: (But with half the AC-compressor)
![Posted Image](http://paceperformance.com/ProductImages/manufacturer/gm/images/12499466.gif)
Posted 09 August 2008 - 07:32 PM
Posted 10 August 2008 - 09:02 AM
Edited by vocky, 10 August 2008 - 09:03 AM.
Posted 10 August 2008 - 06:15 PM
don't forget you need the LSJ alternator too
if you look carefully the belt runs in the opposite direction around the alternator than on the 2.2
LSJ = anti-clockwise
2.2 = clockwise
Posted 12 August 2008 - 06:21 PM
Edited by zezinio, 12 August 2008 - 06:24 PM.
Posted 12 August 2008 - 09:15 PM
Posted 13 August 2008 - 07:57 AM
I might fall for the idea of a supercharger
The LSJ engine sells for about $3000
ECU from motec about $1500
+ can keep the N/A engine as a spear for my zafira![]()
has anyone fitted the lsj engine with another ecu on their car?
Posted 19 August 2008 - 08:15 AM
This is my settings (no pic available though)...
Pic done... (with crappy mobile)
(see some other pics here http://www.vx220.org...mp;#entry752060 )
Edited by Yello, 19 August 2008 - 08:17 AM.
Posted 19 August 2008 - 12:56 PM
Do you know where I can get one of those radiators?
Have been looking around for a suitable radiator to fit in the same position as yours, I don`t want the frontmounted one
Posted 19 August 2008 - 02:52 PM
Posted 19 August 2008 - 04:19 PM
Posted 19 August 2008 - 04:25 PM
I think you edited this out of an earlier post. Is there room for a rad and the air intake behind the same side pod vent?These looks nice, maybe mount one on each side
Posted 20 August 2008 - 05:23 AM
Edited by Yello, 20 August 2008 - 05:24 AM.
Posted 20 August 2008 - 08:39 AM
Posted 20 August 2008 - 11:09 PM
if you look at those, they have the radiator filler cap built in, and they have an extra inlet/outlet next to the cap. What is the procedure for connecting these up to a header tank?
Posted 21 August 2008 - 04:41 AM
Why would you need a header tank if the rads got a filler cap (so long as you can get to it! the header tank is there to give room for expansion and allow you to fill the system. you are not going to get a lot of expansion at the low temperatures needed to intercooling so header tank is not needed imo.
Edited by rik, 21 August 2008 - 04:43 AM.
Posted 21 August 2008 - 07:21 AM
IIRC the explanation I had from CS (in suggesting that for trackwork I was better with the larger CC expansion tank) was the bigger the tank, the more coolant circulating the system and hence the lower the temperature.Why would you need a header tank if the rads got a filler cap (so long as you can get to it! the header tank is there to give room for expansion and allow you to fill the system. you are not going to get a lot of expansion at the low temperatures needed to intercooling so header tank is not needed imo.if you look at those, they have the radiator filler cap built in, and they have an extra inlet/outlet next to the cap. What is the procedure for connecting these up to a header tank?
General Discussion →
Tuning & Modifications →
Anyone Know Where I Can Still Get A Stage 2 M62 Supercharger Kit For ZStarted by alesaux , 11 Jul 2019 ![]() |
VX220 Discussion →
Supercharger ConversionStarted by Chrisp , 06 Dec 2015 ![]() |
Water Injection OptionsStarted by CHILL Gone DUTCH , 08 Nov 2015 ![]() |
VX220 Discussion →
Self Installation Supercharger KitStarted by Singingwolf , 07 Aug 2015 ![]() |
The Market Place →
Car Parts Wanted →
