Correct Front - Bridgestone Potenza RE040BZ 175/55 R17 81W check the DOT code for the letters CAD
I Have ..........- Bridgestone Potenza RE040BZ 175/55 R17 81W dot ejrt cad1807
Correct Rear - Bridgestone Potenza RE040BZ 225/45 R17 90W check the DOT code and for the letters CFE
I Have .........- Bridgestone Potenza RE040JZ 225/45 R17 90W dot ejh8 jdf2307
According to this site the back tyres I have fitted are for an Impreza WRX STi and although I realise that I am not going to be instantly spat into a hedge backwards with these tyres I wondered if anyone knew what differences I would see if I swapped to the correct spec tyre and exactly what the difference is between the manufacturer specific codes that Bridgestone supply tacking into account the impreza tyres currently fitted have the same load index and speed rating?
Edited by ollster, 19 September 2008 - 09:01 PM.
