I imagine that will be a proper PITA then as I assume the rack needs to be removed to fit them?
I think you can get away with fitting them in-situ, if you're careful, by drilling the rivet out. Then undo one of the rack bolts and loosen off the second, then you can rotate the old one out of the and fit the replacement. Then re-insert the removed rack bolt and repeat the process for the second bolt. Once they're both in, torque up the bolts and re-rivet (or not, as they're unlikely to be going anywhere). Check with NickB777 as he was going to use this method, or similar.
yep I used this method , no problem at all
