To get more safe rpm , I am going to change the weak pistons, then I might as well review compression and put a shallower piston on , and rebore it to 87mm
these are 143 spec , 545g
crank, I want to stay with 86mm stroke, but am still compiling details about the OE one
money no object I would go for something like this, Ultra light weight crank shaft 2.0L XE 16V, narrow big end journals, 12.7kg
