Na & Turbo - Various Wheel Weights
38 replies to this topic
#1 drew
drew
  • 181 posts
  • Interests:Cars, bikes, turbo,s. tuning, mapping, rock music.strumpets.
    Car - vx Turbo - Switch,. many mods to come.
Posted 04 January 2009 - 08:10 PM
This will have been asked b4, so forgive me. are the na wheels less weight than the turbo ones. also has any 1 got the weight of the wheels below. is there a chart with them all on. if not please be so kind to fill in what you know, Na wheels front - rear - Turbo wheels front - rear - Speedlines. front - rear Speedline alike front rear any others you care to ad. -- front rear thanks for your time. . chinky chinky
#2 SteveA
SteveA
  • 9,156 posts
Posted 04 January 2009 - 08:13 PM
http://www.lotuscars.../rbf/wheels.php
Info here.
#3 drew
drew
  • 181 posts
Posted 04 January 2009 - 08:50 PM
hi m8, thanks no n a, turbo. or speedline info on there,
Edited by drew, 04 January 2009 - 08:53 PM.
#4 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 05 January 2009 - 12:45 AM
There are a few weights given in the Speedlinealike thread in the group buy room thumbsup
#5 drew
drew
  • 181 posts
Posted 05 January 2009 - 01:38 AM
thanks m8. will take a look. do you know any turbo wheel weights. chinky chinky . D
#6 cheeky_chops
cheeky_chops
  • 7,922 posts
Posted 05 January 2009 - 10:54 AM
all heavy including the speedlines speedlinealikes and TD's are alot lighter. Speedline Mags are very light and very expensive....
#7 rsg
rsg
  • 3,306 posts
Posted 05 January 2009 - 11:21 AM
Right sad as I am I've written this down before Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - ???? Rears - ???? Speedlineaikes Front - ???? Rears - ???? Speedline Magnsiums Fronts - 5.0kg Rear - 6.5kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Can someone please fill in the blanks chinky chinky
#8 snoopstah
snoopstah
  • 3,056 posts
Posted 05 January 2009 - 12:07 PM
Rears - 11.6kg
Rears - 8.0kg
Rears - ????
Rears - ????
Rear - 6.5kg
Rear - 10.1kg
Oz Superturismos Fronts - 7.1kg
Rears - 7.2kg
I think!
#9 techieboy
Posted 05 January 2009 - 12:13 PM
Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - ???? Rears - ???? Speedlineaikes Front - 8.1kg Rears - 10.5kg Speedline Magnesiums Fronts - 5.0kg Rear - 6.5kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Oz Superturismos Fronts - 7.1kg Rears - 7.2kg
#10 mandarinvx
mandarinvx
  • 12,621 posts
Posted 05 January 2009 - 01:38 PM
Speedline / Speedlinealike weight taken from Markiii's weigh in: Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - 11.0kg Rears - 12.0kg Speedlineaikes Front - 8.1kg Rears - 10.0kg Speedline Magnesiums Fronts - 5.0kg Rear - 6.5kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Oz Superturismos Fronts - 7.1kg Rears - 7.2kg
#11 rik
rik
  • 2,187 posts
Posted 05 January 2009 - 01:42 PM
Can I add speedline turinis to the list? I would like to know how much they weigh Thanks
#12 mandarinvx
mandarinvx
  • 12,621 posts
Posted 05 January 2009 - 02:10 PM
Based on a 16*7" front and 17*7" rear the Turinis come in at: Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - 11.0kg Rears - 12.0kg Speedlineaikes Front - 8.1kg Rears - 10.0kg Speedline Magnesiums Fronts - 5.0kg Rear - 6.5kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Oz Superturismos Fronts - 7.1kg Rears - 7.2kg Speedline Turini Fronts - 8.4kg Rears - 8.7kg
#13 JG
JG
  • 13,612 posts
Posted 05 January 2009 - 03:07 PM
i think the std turbo wheel is ever so slightly lighter than the NA wheel. Or maybe its the other way round. I can't remember :D
#14 chris_uk
Posted 05 January 2009 - 04:14 PM
im swapping my na wheels for tubby ones on wednesday so i will tell you then.. although my measurements will be with tyres on at least ill be able to tell you which are heaviest
#15 jasvxt
jasvxt
    Scary
  • 4,527 posts
Posted 05 January 2009 - 04:39 PM
Do these weights include the tyres ? :) How heavy are the tyres ? :D How much does the air in the tyres weigh ? :lol:
#16 rik
rik
  • 2,187 posts
Posted 05 January 2009 - 04:51 PM
hmm so speedline turinis are approx 1kg more each corner than the TDs.. which counteracts the 1kg you save with the hub change :wacko: I might just look for some TDs rather than contemplating the hub & disk change
#17 alanoo
alanoo
  • 1,324 posts
Posted 05 January 2009 - 06:27 PM
Rear - 6.5kg
Never... in your dreams only
Fronts are 6.7 Kg
and Rears are 8.1 Kg...
Measured by chris who has a set, all other weights on these magnesium wheels are just marketting stuff
Edited by alanoo, 05 January 2009 - 06:29 PM.
#18 alanoo
alanoo
  • 1,324 posts
Posted 05 January 2009 - 06:33 PM
Front TD 1.2 is 7.9 Kg for me, in ET25 and respectively 8.7 / 9.4 / 10.0 for the 7.5x17 / 8x17 / 9x17 ones These ones are straight from Team Dynamics France
#19 drew
drew
  • 181 posts
Posted 05 January 2009 - 08:29 PM
some good wheel info coming up here. keep it up lads. chinky chinky :groupjump:
Edited by drew, 05 January 2009 - 08:31 PM.
#20 Dominique
Dominique
  • 138 posts
Posted 05 January 2009 - 11:17 PM
Based on a 16*7" front and 17*7" rear the Turinis come in at: Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - 11.0kg Rears - 12.0kg Speedlineaikes Front - 8.1kg Rears - 10.0kg Speedline Magnesiums Fronts - 5.0kg Rear - 6.5kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Oz Superturismos Fronts - 7.1kg Rears - 7.2kg Speedline Turini Fronts - 8.4kg Rears - 8.7kg ATS DTC 17*7,5 J Fronts - 8,1-8,4 kg 17*9J Rears - 9,1-9,3 kg The weight differance is depending on race or road version. The race version has 5 additional holes drilled in the centre to reduce weight. It might might be an idea to introduce rim diameter on the front ones. It wouldn't be fair to compare 16" with 17" rims. Anyway, great work, these lists chinky chinky
