Na & Turbo - Various Wheel Weights
38 replies to this topic
#21 2-20
2-20
  • 1,316 posts
Posted 06 January 2009 - 07:24 AM
Standard Turbo (i think) Fronts - 9.8kg
Rears - 11.6kg
Team Dynamics Front - 7.3kg
Rears - 8.0kg
Speedlines Fronts - 11.0kg
Rears - 12.0kg
Speedlineaikes Front - 8.1kg
Rears - 10.0kg
Speedline Magnesiums Fronts - 6.70kg
Rear - 8.1kg
Compomotive MOs Front - 8.3kg
Rear - 10.1kg
Oz Superturismos Fronts - 7.1kg
Rears - 7.2kg
Speedline Turini Fronts - 8.4kg
Rears - 8.7kg
ATS DTC 17*7,5 J Fronts - 8,1-8,4 kg
17*9J Rears - 9,1-9,3 kg
Oz Superleggera Fronts - 6.9 kg
Rears - 8.3 kg
As weighted HERE
Edited by 2-20, 06 January 2009 - 07:26 AM.
#22 PaulCP
PaulCP
  • 6,064 posts
Posted 06 January 2009 - 09:03 AM
At the risk of being controversial why the obsession with wheel weights :closedeyes: How many of us are good enough driving gods to be able to feel the difference in unsprung weight on a track let alone on the road :tumble:
#23 2-20
2-20
  • 1,316 posts
Posted 06 January 2009 - 09:28 AM
I can tell you that i do feel the difference between my stock NA wheels and my OZ superleggera on bumpy roads.
It not only affects the handling but the ride is also smoother .
On a flat road, i can't feel it.
Edited by 2-20, 06 January 2009 - 09:28 AM.
#24 Dominique
Dominique
  • 138 posts
Posted 06 January 2009 - 11:52 AM
In most cases new tyres will be installed on new rims, which makes it hard to tell where the difference in car handling comes from. When replacing the originals, rims size will be likely to change too. What I noticed with reducing weight on wheels (rotor upgrade, -3,5kg each corner), that it reduces the effort needed to turn the steering wheel or change car direction at high speed. Think of corrections you make on long fast turns, etc. This was noticable on public road, without paying much attention on it! I didn't feel any change on the rear thou but it must have a positive effect on overall grip: the lighter the wheels the better they are to control by the suspension.
#25 drew
drew
  • 181 posts
  • Interests:Cars, bikes, turbo,s. tuning, mapping, rock music.strumpets.
    Car - vx Turbo - Switch,. many mods to come.
Posted 07 January 2009 - 11:48 PM
cheers to all for the input. :) any info on the. oz .Ultra. Leggeras or are they the same as the supers. :)
Edited by drew, 07 January 2009 - 11:55 PM.
#26 Dominique
Dominique
  • 138 posts
Posted 12 January 2009 - 03:12 PM
It took me a while to find it again....
Wheel Weights.net hasn't been updated for 1.5 years, but it is still a very complete overview. :)
#27 The Batman
Posted 06 February 2009 - 05:16 PM
bump! is the weight of standard na wheels the same as standard turbo alloys? Standard NA front -??? Rears - ??? Standard Turbo (i think) Fronts - 9.8kg Rears - 11.6kg Team Dynamics Front - 7.3kg Rears - 8.0kg Speedlines Fronts - 11.0kg Rears - 12.0kg Speedlineaikes Front - 8.1kg Rears - 10.0kg Speedline Magnesiums Fronts - 6.70kg Rear - 8.1kg Compomotive MOs Front - 8.3kg Rear - 10.1kg Oz Superturismos Fronts - 7.1kg Rears - 7.2kg Speedline Turini Fronts - 8.4kg Rears - 8.7kg ATS DTC 17*7,5 J Fronts - 8,1-8,4 kg 17*9J Rears - 9,1-9,3 kg Oz Superleggera Fronts - 6.9 kg Rears - 8.3 kg
#28 drew
drew
  • 181 posts
Posted 09 February 2009 - 12:48 AM
so many people must have a bent std alloy they can pop on the scales. D
#29 Paulus H
Paulus H
  • 2,063 posts
Posted 13 February 2009 - 11:51 PM
Your car looks very cool. Personally I am not interested in making my car look like its previous owner has moved onto a 1.2 Nova with 19 inch wheels and the boot filled with stereo equipment. What wheels have you fitted? I am referring to Dominique's machine....
Edited by Paulus H, 13 February 2009 - 11:53 PM.
#30 Bobo82
Bobo82
  • 99 posts
Posted 28 October 2009 - 01:16 PM
I just weighed a set of NA Wheels with Bridgestone Potenza’s all round and; Rears : 21.5 KG Fronts 17.6 KG Just in case anyone needs to know combined weight of alloy and tyres.
#31 Code Monkey
Code Monkey
    forum whore
  • 2,425 posts
Posted 28 October 2009 - 02:34 PM
Do these weights include the tyres ? :)
How heavy are the tyres ? :D
How much does the air in the tyres weigh ? :lol:
Is there a benefit in filling the tyres with Helium instead of Nitrogen?
#32 TheRealVXed
TheRealVXed
    Sidekick
  • 5,975 posts
Posted 13 January 2010 - 09:23 PM
Rears : 21.5 KG
Fronts 17.6 KG
is that the wieght for the pair? or for each with a tyre?
cheers
#33 Mangham54
Mangham54
    Wannabe....
  • 12,034 posts
Posted 14 January 2010 - 01:03 PM
Rears : 21.5 KG
Fronts 17.6 KG
cheers
That has to be for a single wheel and tyre.... Tyres are suprisingly heavy!
#34 Steve B
Steve B
  • 964 posts
  • Interests:Mountain Biking and Cars
Posted 14 January 2010 - 06:43 PM
Ultra's are the replacement of the discontinued supers, I have Ultras on my track car. Has to be said the finish on the OZ wheels makes TD look home made - in a bad way.
#35 Paulus H
Paulus H
  • 2,063 posts
Posted 16 January 2010 - 12:41 AM
Now this is going to sound really anal... Has anyone weighed different tyres????
#36 Dominique
Dominique
  • 138 posts
Posted 16 January 2010 - 07:07 PM
Sorry I missed your post from almost a year ago... :blush:
The rims are ATS DTC's, the lighter race version. (search should bring you some info on this forum)
At the moment I've R888 tyres installed but I will be trying the Kumho semi's this year.: 205/40R17 front (no probs with rubbing, see pic) and 235/40R17 rears.
The rear tyres only touch slightly when riding height is reduced to two inches. :lol:
Good point, tyres weigh approx the same as a rim, but regarding dynamics they have more influence on handling because the weight is further from the centre of the wheel.
In this German Semi Comparison Test, you will find some weights on page 5.
Mind that the size they've tested is 255/40R18.
#37 2-20
2-20
  • 1,316 posts
Posted 19 April 2020 - 04:54 PM
Thread resurrection as I was looking for NA OEM front wheel weight...
I couldn't find here....
But the NA rear wheel weight is 11.8 kg
#38 border
border
  • 19 posts
Posted 19 April 2020 - 06:30 PM
I weighed my NA wheels + tyres when I removed them; they measured 16.8/22.1kg front/rear on my scales with a very low front tyre and decent tread on the rear.
I replaced them with a set of forged Exige wheels that weighed 14.5/16.3kg front/rear including good tyres, and with 4-stud hubs and 2-piece brakes saved just under 28kg of unsprung rotational mass in total (which went a long way toward offsetting the extra weight of a supercharger conversion).
The new rear wheels were lighter than the OEM fronts, despite being 2.5" wider!
#39 pete-r
pete-r
  • 2,771 posts
Posted 19 April 2020 - 08:39 PM
The savings are unsprung so in terms of performance it's more like taking 50-70kg out of the car if you listen to F1 teams.
The car felt much more delicate to drive after going forged.
