My New Project
488 replies to this topic
#261 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 29 May 2009 - 09:00 PM
One step closer to full stealth B)
#262 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 May 2009 - 09:48 PM
is it what i think adam ...is it the one i sent you :wub:
come on i need to do mine now :D
#263 mandarinvx
mandarinvx
  • 12,621 posts
Posted 29 May 2009 - 09:53 PM
It is indeed B)
#264 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 May 2009 - 10:06 PM
It is indeed B)
i need one can you sale me one :D already done of course
looking good thumbsup
Edited by crazyfrog, 29 May 2009 - 10:07 PM.
#265 mandarinvx
mandarinvx
  • 12,621 posts
Posted 29 May 2009 - 10:12 PM
I actually gave it a light coat of paint over the top of the anodising, the one I painted for the first car chipped on the corners slightly, but if it does it this time the black underneath will show through :)
#266 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 May 2009 - 10:14 PM
so you telling me i shouldn't do this one adam :(
#267 mandarinvx
mandarinvx
  • 12,621 posts
Posted 29 May 2009 - 10:18 PM
Nah, not saying that; but it may be worth waiting a couple of weeks so I can see how this one stands up - I baked the paint this time too thumbsup :)
#268 Crazyfrog (Fab)
Crazyfrog (Fab)
  • 22,801 posts
Posted 29 May 2009 - 10:20 PM
i will be very patient and will wait for your reply ;)
#269 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 June 2009 - 08:05 PM
Goodies arrived today :D
6" dia, 29" long silencer system
With 4-1 manifold
And to complete the stealth look B)
#270 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 June 2009 - 09:45 PM
The new 'diet version' sub-box is starting to look a little more promising :)
#271 Pete0810
Pete0810
  • 1,196 posts
Posted 01 June 2009 - 10:23 PM
I have a VSE yep, but Ad's has the Regal which just sounds great, better than the VSE i think.
Yeah, it sounds fantastic but is incredibly loud! I followed him at low speed with my VSE inaudible because of his Regal!
I think it will need stitching, unless you think otherwise :unsure:
Yes, think it will. Certainly will need to be done in panels. It may be possible to glue fabric to console and marry pattern up but probably best stitched. I have not experimented yet so we shall see.........
I wrapped leatherette cloth around the centre console of mine and glued it down. It worked fine but, of course, there's no print like carbon fibre to align:
#272 mandarinvx
mandarinvx
  • 12,621 posts
Posted 01 June 2009 - 10:32 PM
What did you use to glue it with - I'm worried it will lift away over time :unsure:
#273 Pete0810
Pete0810
  • 1,196 posts
Posted 02 June 2009 - 03:12 PM
I did it two years ago and it's still holding firm to door cards, door handle guards, dash and centre console. The gluing was a sod. I used araldite, smeared everywhere, and a hot glue gun for getting those awkard turns and folds to grip. If I did it again, and I'm considering redoing the door cards and dash, I'm going to use some sort of finer spray on glue because araldite is tough to smooth down without leaving the odd lump or bump. I'm really impressed by your project, by the way, I'll get around to doing my leaky headlights one day! thumbsup
#274 mandarinvx
mandarinvx
  • 12,621 posts
Posted 02 June 2009 - 03:31 PM
:) I've used spray glue on mine so far - but it's still a bit bumby - I have some spray exostick to try yet tho...
#275 XXX
XXX
    Invisible ex-VX owner
  • 4,471 posts
Posted 02 June 2009 - 04:33 PM
Adam, I have started on my dash plates. I have used 3M Craft Mount Permanent Adhesive spray. It is very good. Fine spray, no lumps or bobbly bits and sticks well. Spray, wait 20 seconds or so and adhesion is good. Not too easy to reposition though :rolleyes: . I will post up some phoos in a new thread when I get a moment.
#276 mandarinvx
mandarinvx
  • 12,621 posts
Posted 02 June 2009 - 05:59 PM
:wub: I love sticky tyres :wub:
#277 mandarinvx
mandarinvx
  • 12,621 posts
Posted 02 June 2009 - 06:00 PM
Cool, I'll try and track some down - Aldi had run out of their version :(
#278 mandarinvx
mandarinvx
  • 12,621 posts
Posted 02 June 2009 - 08:17 PM
Thought I'd have a look at what will be involved in fitting the new exhaust today :)
This is what was left of the small hanger bracket - new one on order
Well at least this one actually resembles a bolt of some form
Unlike the others :rolleyes:
Had to cut the heads off
And then drill them / knock them through
And finished at last
Thankfully the bolts at the manifold join don't look anywhere near as bad!
#279 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 02 June 2009 - 09:16 PM
That's what mine looks like. Good to know it cleans up that well! thumbsup I hadn't looked at it closely, but from a distance it looks like it would fall apart at the sound of power tools. :rolleyes:
#280 mandarinvx
mandarinvx
  • 12,621 posts
Posted 08 June 2009 - 06:51 PM
Picked the head up on the weekend, after the work at Headline MK
Valve seats machined / enlarged to accomodate the 0.5mm O/S valves
Valve seat close up
GM Performance guides fitted
And valves shaped
Also had a skim
