My New Project
488 replies to this topic
#281 mandarinvx
mandarinvx
    King of First Replies
  • 12,621 posts
Posted 13 June 2009 - 08:08 PM
Finally got around to sorting out the ABS light today. I'd already traced it to the NSF wheel, so bought a connector from a breakers; it had already had a bodged repair at some point in the past :rolleyes:
And all fixed :)
Also painted the AP logo on the calipers yellow whilst I was there
And gave the roof a final clean with Autoglym, all traces of green now gone :D
Edited by mandarinvx, 13 June 2009 - 08:09 PM.
#282 mandarinvx
mandarinvx
  • 12,621 posts
Posted 13 June 2009 - 08:27 PM
PS, for future reference the front and rear connectors are different types thumbsup
#283 TOTAL VX
TOTAL VX
  • 37 posts
Posted 20 June 2009 - 08:56 AM
Well I have now done it. K&N, Airbox pipe mod, stainless exhaust with precat pipe, standard cat, remap, goodrich hoses, redstuff, silver comps and 888's. I AM ADDICTED. However what difference did the GAZ shocks and Geo make? Was the ride better or worse and turn in? Cheers TOTAL
#284 mandarinvx
mandarinvx
  • 12,621 posts
Posted 20 June 2009 - 02:24 PM
The Gaz shocks made a massive difference over standard. I prefer running a low ride height, tho I must admit I think I'm going to have to raise it a bit to make bumpy roads a pleasure to drive again (instead of cringing every time I see a large bump!) The geo will affect turn in - My last car had a very harsh geo at Topgear Automotive, and I absolutely loved it :D I currently have a Guglielmi geo, which is great, but I think I may go back and get the steering arms machined down to allow for extra camber (as they did with the Topgear geo) This does give a bit more tramlining on the straight tho, and seems to enhance bump steer, so if you spend most of your VX time on the motorway it may not be advisable :)
#285 mandarinvx
mandarinvx
  • 12,621 posts
Posted 21 June 2009 - 05:44 PM
Playing with Gaz... So far I've had Gaz standard on 8" 325F, 9" 375R - 90mm ride height front 8" 375F, 9" 450R - 80mm ride height front And Gaz Gold on 7" 400F, 9" 475R - 80mm ride height front 8" 425F, 9" 475R - 80mm ride height front And just changed over to: 8" 425F, 9" 550R - 100mm ride height front Must admit all have been great, I've been expecting a point when the springs are too stiff to be unusable on road, but although noticeably firmer the 550's still feel fine. The 325 front springs worked well, and the only reason I started playing was how close the nose was getting to the track due to the low ride height (removing a skim of paint in one instance, and mandarin wasn't easy to match!) The 7" front worked well on a very low car, but do hit the bump stops more regulary I've raised the car ~20mm this time; on the last car the lowest ride height worked best, whereas turn-in doesn't appear to have been affected much going up 20mm this time, maybe something to do with the Guglielmi geo (which will now need to be done again :rolleyes:)
Edited by mandarinvx, 21 June 2009 - 07:15 PM.
#286 _JoE_
_JoE_
  • 81 posts
Posted 22 June 2009 - 07:05 PM
Really nice job Mandarin, car is looking great. How's the engine coming along? I heard that you can remove the lens by sticking them in the oven, i'm guessing using a heatgun is a bit safer? I'm needing to remove the rear drivers unit as somehow i have sand in it.. Joe
#287 mandarinvx
mandarinvx
  • 12,621 posts
Posted 22 June 2009 - 07:08 PM
Yeah, I'd go for the heat gun option, only use the oven as a last resort :) I'm waiting for Vocky to get back from his travels so he can help me re-assemble the head - I don't have any valve spring compressors that will fit (and I have no idea where to start :lol:)
#288 aron916
aron916
  • 2,055 posts
Posted 23 June 2009 - 07:02 AM
When the broken wire is that short how have you re-attached it securely? mine was even shorter than that and am expecting the light to come on again pretty soon!
#289 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 23 June 2009 - 04:50 PM
He had another connector with wires. Do you want one? I have the full set.
#290 mandarinvx
mandarinvx
  • 12,621 posts
Posted 23 June 2009 - 05:01 PM
I bought a connector from a breakers with about 10" cable left on the end of it, then cut the existing and connected them together (hence the copius amounts of PVC tape :D)
#291 _JoE_
_JoE_
  • 81 posts
Posted 25 June 2009 - 06:48 PM
I'm waiting for Vocky to get back from his travels so he can help me re-assemble the head - I don't have any valve spring compressors that will fit (and I have no idea where to start :lol: )
Vocky sounds like a busy guy, he seems to have a hand in nearly all engine projects.
Ok definitely going for the heatgun approach then as bad things normally happen when I put things in the oven! :rolleyes:
#292 mandarinvx
mandarinvx
  • 12,621 posts
Posted 11 July 2009 - 09:17 AM
After my trip to Hoffmans, found that a couple of things needed doing before I was comfortable taking the car out on track, so Techieboy very kindly volunteered his help, and we (well, he) replaced the OSF lower wishbone ball joint:
The old one was very worn, and the play in the wheel has now dissapeared - real PITA of a job tho!
And the NSF wheel bearing, looks like this may have been the true cause of my intermittent ABS light - the ABS sensor housing had seperated from the hub!
Thanks again to Matt for all his help :grouphug:
#293 mandarinvx
mandarinvx
  • 12,621 posts
Posted 12 July 2009 - 03:32 PM
As part of the bush refresh I set out changing the ARB bushes for polyurethane ones and the droplinks for OEM replacements - Elise Parts were very helpful on the phone thumbsup
First off I had to jack the front up - a bit nerve wracking as I've never lifted a car in this way before :D
The old bushes were looking very tired - cracked through in places -
I undid the drop links first - a true PITA after 7 years of corrosion has taken place - had to get the dremel out for two of the four nuts :rolleyes:
Then onto the ARB bush mountings. Removed the front undertray, then cut off a long section of 6mm allen key to be able to get to the top set screw
Then onto the lower one - what a ridiculous place to locate them - slap bang in the middle of the wishbone travel :9mm:
So had to udo the front bolts of the lower wishbones and knocked them up a bit, as advised in SteveA's thread thumbsup
Bar replaced and new droplinks fitted (they don't come with washers for some reason, and I had no 10mm ones :rolleyes:)
Then bolted back up again, used stainless ones for re-assembly, and a hex head on the lower one so I don't have to move the wishbone if it ever has to come off again
New bushes in place
So overall, a very long winded, PITA process
#294 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 12 July 2009 - 05:20 PM
Can I PLEASE have one of your old droplinks? I need one intact rubber boot. :wacko:
#295 mandarinvx
mandarinvx
  • 12,621 posts
Posted 12 July 2009 - 05:24 PM
No probs :) One of the drop links is in good (but rusty!) condition, the other had a split boot PM me your address thumbsup
#296 mandarinvx
mandarinvx
  • 12,621 posts
Posted 26 July 2009 - 03:16 PM
Changed the sub out for the new box I've made today
Still sounds great (which is a bit of a relief, in fact at sensible volumes it's hard to tell the difference! though I did spend quite some time looking at which 6x9"'s to go for :))
#297 alanoo
alanoo
  • 1,324 posts
Posted 28 July 2009 - 10:38 AM
Not sure stainless steel bolts there were a good idea. There's not much much stress, but still unsure
#298 theolodian
theolodian
    Recovering VX owner
  • 3,195 posts
Posted 28 July 2009 - 06:07 PM
mandarinvx, on Jul 12 2009, 19:06 , said:
No probs :)
Received in good order a little while back. Thanks a ton! thumbsup
#299 mandarinvx
mandarinvx
  • 12,621 posts
Posted 30 July 2009 - 04:38 PM
I did wonder myself as a lot of the force will be seen in shear - if I'd used an uprated ARB I deffo would have got some graded mild steel ones
#300 Anton
Anton
  • 70 posts
  • Interests:Love everything that i don't understand, engines, computer issues, people.
    Usually go for a inline exercises (2-4 metric miles) during summer times, roadtrips with the speedster, scuba diving, programming and scripting websites.
Posted 11 August 2009 - 12:10 PM
I've been looking through the guide now for the last 30 min. at first i thought i'd give you credit for a few things, but dear christ... You've reconditioned the hole bloody car :P Got a perfect guide for the roof sealing (mine has started leaking a tiny tiny bit on the passenger side. A bloody awesome guide for speaker box (altho i don't know how to work with fibreglass, i would love to know how tho). And the best part was probably the lighting house, i need to go over those myself. THANK YOU!
7 user(s) are reading this topic
    Bing (4)
